Author Topic: Meyer-Photogrammetry Buggy Cell Vessel  (Read 1107 times)
« on: February 27, 2011, 22:42:17 pm »
Here's some rough clips and photos of a Dune buggy Component
Video Sources: 1 WTVN News Report: 2 Water Fuel Cell Demonstration Tape: 3 Backyard Buggy Video
License plates are standardized at 12 by 6 inches in the USA
Bolts are evenly spaced, Dimension of pressure gauge around 3 inches, Initial estimate of 12 to 14 inch diameter vessel Rough guess is that the cap rim is about 2 inches
First run through  on possible parts availabilty
parts sift
<val> source MCMC
attribute <val> string:tank:plastic:lid:removable:<val> od <12,20>:<val> h <12,30>
AI image acquire
AI***
design modification
<val> CH = 0
larger vessel acts as CH
ref <val>ITOW: dim<val>liquid
water added to CH
single plug
This is interpreted that because Stan is adding water to a single cell in the It Runs on Water video and that the white buggy vessel has only one port as far as is visible, then the vessel itself is the cell holder for all the cells and that individual cell holders are not necessary (<val> CH = 0)
run smart srch
3687K103
3687K111
3687K103
Easy-Drain Polyethylene Cylindrical Tank 15 Gal, 15-5/8" Body Dia X 22-3/4" H, 3/16" Thk Wall[/t][/t][/t][/t][/t][/t]
In stock at $127.69 Each
« Last Edit: March 04, 2011, 18:52:12 pm by jim miller »
