Author Topic: Meyer-Photogrammetry I7B Bolt Thread Size  (Read 1178 times)
« on: February 25, 2011, 05:58:22 am »
Caliper measurements 186 and 70
argument 186:35:.190:<val>
ratio .357
1/24 =.416
1/28 =.357
1/32 =.312
parts sift
<val> source MCMC:
attributes<val> string: stainless:rod:316:dim<val> 10
run smart srch
90575A364
90575A436
90575A364  Each      In stock for $1.34   FALSE
Material Type
Stainless Steel
Finish
Plain
Grade/Class
Not Rated
Type
Fully Threaded Rods and Studs
Stainless Steel Type
316 Stainless Steel
Thread Direction
Right Hand Thread
Inch Thread Size
10-24
Overall Length
3"
Rockwell Hardness
Minimum B70
Minimum Tensile Strength
70,000 psi
Thread Fit
Class 1A
Specifications Met
Not Rated
Notes
Length is measured from end to end.
90575A436  Each      In stock for $1.20   FALSE
Material Type
Stainless Steel
Finish
Plain
Grade/Class
Not Rated
Type
316 Stainless Steel
Thread Direction
Right Hand Thread
Inch Thread Size
10-32
Overall Length
3"
Rockwell Hardness
Minimum B70
70,000 psi
Thread Fit
Class 1A
Specifications Met
Not Rated
Notes
« Last Edit: February 25, 2011, 13:59:52 pm by jim miller »
