Author Topic: Stan Meyer-Photogrammetry IT4 Hole  (Read 1310 times)
« on: February 24, 2011, 08:02:31 am »
Here is detail of the an inner tube of the Meyers Demonstation Unit. The tube IT4 shows evidence of being drilled(as do IT3 and IT1) The mark on the opposite side on the inner wall of IT4 shows the drilling did not go all the way through
argument 670:440
ratio 1.52
argument 0.75:.50
ratio 1.50
argument 440:.50::112:<val>
ratio .125
cl =.99
passes fuzzy matrix <val>eng drl sz
passes fuzzy matrix for <val> dim <spacer bar>source
D9 <val>UTSD
end
This is interpreted as follows: The ratio of the caliper measurements is very close to the ratio of the
reported diameter of the inner and outer tubes
The value of the caliper value of the hole is consistent with a 0.125 diameter hole when related to known values of the inner and outer pipes
The confidence level is 99%  (at least 5 matrix cross links of high reliabilty)
This is based on known dimensional string consistency
This is based on english drill size matrix
This is based on availabilty of .125 diameter plastic rods
The is based on D9 statement on diameter of the upper tube spacers
part sift
<val>source MCMC:
attribute: <val> string :acrylic:rod:diao<val>.125
run smart srch
8531K11
return search
8531K11  Each      In stock for $0.36    FALSE
Material
Acrylic
Acrylic Material
Extruded Acrylic
Backing
Plain Back
Finish
Smooth
Shape
Rods and Discs
Rods and Discs Type
Rod
Length
6'
Length Tolerance
+1/2"
Diameter
1/8"
Diameter Tolerance
±.005"
Clear
Clear with No Tint
Operating Temperature Range
+32° to +160° F
Tensile Strength
Good
Impact Strength
Poor
Tolerance
Standard
Hardness
Rockwell M89-M96
Specifications Met
Underwriters Laboratories (UL)
UL Rating
UL 94HB
end
AI image aquire
AI***
possible test hole drilled
possible tuning hole
<val>stainless<val> dim:hardness
<val>acoustic>:<val>frequency:<val>adjust
end
This is interpreted as:
Stan may have drilled some test holes before he started to make holes for the spacers because of drilling difficulty or bit breakage.
Stan may have reduced mass of the tubes in an experiment or method of adjusting acoustic frequency
AI***
update
D9<val>availabilty:<val>scrap
AI***
possibility holes in original material
Based on Photo0068.jpg  graciously posted by Dynodon
« Last Edit: March 27, 2011, 01:09:05 am by jim miller »
Re: Meyer-Photogrammetry IT4 Hole
« Reply #1 on: February 25, 2011, 23:28:43 pm »
Same picture panned out...
« Reply #2 on: February 26, 2011, 00:39:26 am »
Like I said before,just a bunch of scrap tubes
