Author Topic: Demo Cell Parts Plumbing and Measurements (Update 1)  (Read 1649 times)
« on: February 18, 2011, 15:10:51 pm »
Added abbreviations
These are all standard plumbing parts
See the video "It runs on water" for views of the top plumbing assembly
 PLUMBING Parts Gas Nozzle Assembly GNA Gas Control Valve GCV Gas Exit Port GEP Gas Shut-off Valve GSV Gas Flow Valve GFV Gas Flow Gauge GFG Gas Pressure Gauge GPG Water Inlet Plug WIP Conical Gas Fitting CGF Gas Assembly Nipple GAN
GFV Gas Flow Valve-----------
GNA Gas Nozzle Assembly ------
GSV Gas Shut off Valve---------
WIP Water inlet plug -----------       stainless in ITOW video, specs attached
GCV Gas control valve
GFG gas flow gauge------------
GPG Gas Pressure Gauge--------      15 psi in orginal see ITOW video
GAN Pipe tees and nipples ------      Standard Plumbing parts, black iron pipe used
68115K41  Each      In stock for $4.40   FALSE
Shape
Tee
Tee Type Pipe to Pipe
Standard Tee
Pipe to Pipe Connection
NPT x NPT
System of Measurement
Inch
Pipe Size
1/2"
Finish
Black
Iron
Cast Iron
Maximum Pressure @ 72° F
125 psi
Maximum Pressure Note
For steam, maximum pressure is 125 psi @ 353° F.
For Use With
Schedule 40 steel nipples and pipe
Specifications Met
American National Standards Institute (ANSI), American Society of Mechanical Engineers (ASME), American Society for Testing and Materials (ASTM), Factory Mutual (FM), Underwriters Laboratories (UL)
ANSI Specification
ANSI B1.20.1
ASME Specification
ASME B1.20.1, ASME B16.4
ASTM Specification
ASTM A126 Class A
CGF Conical Gas Fitting
teflon tape for gas sealing  ---- -----gas sealing type preferred\
1/2"4591K121.741.56     MSDS|Catalog Page|BookmarkBookmarked|
« Last Edit: February 26, 2011, 13:10:17 pm by jim miller »
