Author Topic: Demo Cell Parts-Plexiglas( Update 1)  (Read 1301 times)
« on: February 18, 2011, 15:08:18 pm »
Added abbreviations and another attachment with parts ideas, order numbers
Plexiglas
 ACRYLICS Tube Spacing Bar TSB Top End Cap TEC Botton End Cap BEC Support Base SB Support Base Rod SBR Cell Housing CH
1. Sheeting for TEC and BEC
2. Cell Housing Tube    CH
3. Sheeting for Support Base Assemby SBA
4. Support Base Rods SBR  for attaching Support Base Assembly to BEC
Dimensions
1 Plexiglas Sheet for fabrication of BEC and TEC --------- 2.5 inches thick
2 Cell Housing  5.5 inches OD, 0.375 wall thickness ,24 inches long (as in original)
           or       6.0 inches OD, 0.50 wall thickness , 24 inches long( higher spec for safety)
3 Plexiglas Sheet for Support Base Assembly   0.5 to .75 thick 14 x14 or 16 x 16 for good stablity
4 Plexiglas Rods for attaching  BEC to SBA ---0.75 to 1.00 OD ,2 to 3 inches long
You may want to use stronger options for safety reasons.
Also consider purchasing rod and slilcng or milling to thickness to avoid having to turn discs yourself
« Last Edit: January 06, 2012, 20:09:20 pm by jim miller »
