Author Topic: Meyer-Photo0066.jpg Photogrammetry 1  (Read 2371 times)
« on: February 08, 2011, 18:17:03 pm »
Release of Stanley Meyer Photo0066.jpg with matrix overlay
Includes Gauges of I7B's,the ETP ,some McMaster part numbers, GSB, gasket ratios and cap screw closeup
I posted 7 Photo0066.jpg's with matrix overlay and part
search. Lost one photo in transmission so I searched by ratio size to replace it..
Delete error**Sfile shred**
Recov fail:srch simpic Photo0066
Search resize ratio search .260 matrix
Confirm with 3
Nearest part <ETP>
Gaugelnk array
  http://www.engineeringtoolbox.com/gauge-sheet-d_915.html
**recovery**
3d matrix confirm on gaugelink
<val> 0.500
Gauge SS <ETP> = val (0.500) english  18 gauge
recovery complete link ETB matrix
File BEC z-axis, parts availability, ratio-relational matrix applied,
english measurement
Print
Best fit part to ratio-relational matrix: MMC 9957k929
Ratio .664   argument:: Matrix:z:English: 0.499:0.251
Iteration to .001
Hardware  Search
Category Cap Screw:5/16:ss316/all/HH:7/8: full thread
Catagory Lock Washer Regular Spring:5/16/H/all
Iteration to .05
36 options
3 options
Best Match 13/64:.203::0.078
Ratio 2.60 argument:: Matrix:z:English: 391:149 Calc 2.62
List Best::
93190A582:::
Head Style
Standard Hex
Material Type
Stainless Steel
Finish
Plain
Grade/Class
Not Rated
Stainless Steel Type
316 Stainless Steel
System of Measurement
Inch
Inch Thread Size
5/16"-18
Length
7/8"
Head Width
1/2"
Head Height
13/64"
Thread Length
Fully Threaded
Thread Fit
Class 2A
Thread Direction
Right Handed
Self-Locking Method
None
Rockwell Hardness
Minimum B70
Minimum Tensile Strength
70,000 psi
Specifications Met
American Society of Mechanical Engineers (ASME)
ASME Specification
ASME B18.2.1
Screw Quantity
Individual Screw
92147A030
Shape
Spring Lock
For Screw Size
5/16"
Material Type
Stainless Steel
Finish
Plain
316 Stainless Steel
Spring Lock Type
Standard
Inside Diameter
.32"
Outside Diameter
.59"
Minimum Thickness
.07"
Application
Locking Washer
Rockwell Hardness
Minimum C35
Specifications Met
ASME Specification
ASME B18.21.1
http://www.mcmaster.com/#
BOR search
Assume 4 in I.D
Source paste:
AS568A Dash Number
421
Type
O-Ring
O-Ring Type
Standard
Cross Section Shape
Round
Width
1/4"
Actual Width
.275"
Inside Diameter
4"
Actual Inside Diameter
3.975"
Outside Diameter
4-1/2"
Actual Outside Diameter
4.525"
Material
EPDM (Ethylene Propylene)
EPDM Type
Standard
Durometer
Hard
Durometer Shore
Shore A: 70
Temperature Range
-65° to +212°F
Color
Black
Note:
If the measurements of the basic scale elements is good ( high resolution) and the number of possible parts can be limited through dimensional, material or availabilty constraints then
photogrammetric input data and ratio matrices can search the materials data base in a timely manner. Otherwise it just turns into an NP deterministic problem with no solution possible.
An error in measurement in the first part of a ratio string  corrupts the subsequent operations, hence the need for precise starting input. Likewise if the materials database is not standardized in format such as ASTM, the matrices cannot
search efficiently.
photo0066.jpg BEC
y axis
QRA run
   argument 853:322
   Ratio 2.64
   2.64 *(<value BOR >) *3= 1.98
2 inches + dim(hid)flange to equal BEC height
Tolerance value set<.05
2.5 inches reported ref D19 <val wt 8>lnk:attribute fmt
Fuzzy Matrix Test
0.5 passes reasonable thickness
2.5 passes reasonable height
2.5 inch height for BEC
recovery update Fuzzy Matrix Test
val 0.500 ETB.lnk passes reasonable availability
availability sieve > 0.95
Part ETP--18 gauge
C.L > .99
Photo0066.jpg GSB
argument 422:256
Ratio 1.648
1.648 * val <GSB> = 1.238
RndRL (.25)
0.75 Diameter, 1.25 Height
Search McMaster
Shape: Rod
Material: Stainless Steel
Type: 316L
Diameter: 0.875
Length: 1 ft
Part 9298K151
Material
Super-Corrosion-Resistant Stainless Steel (Type 316/316L)
Finish/Coating
Unpolished (Mill)
Shape
Rods and Discs
Diameter
7/8"
Diameter Tolerance
±.002"
Length
12"
Length Tolerance
±1"
Straightness Tolerance
1/16" per 5 feet.
Tolerance
Standard
Test Report
Without Test Report
Condition/Temper
Annealed
Hardness
150 Brinell
Yield Strength
33,000 to 42,000 psi
Specifications Met
Aerospace Material Specifications (AMS), American Society for Testing and Materials (ASTM)
AMS Specification
AMS5648, AMS5653
ASTM Specification
ASTM A276, ASTM A479
Note
Also known as Project 70+, offers better machinability for an improved finish and longer tool life. Cold finished.
WARNING
Hardness and yield strength are not guaranteed and are intended only as a basis for comparison.
Time: :03
Error data resubmit***
Search McMaster
Shape: Rod
Type: 316L
Diameter: 0.75
Length: 1 ft
Part 9298K141
Material
Finish/Coating
Unpolished (Mill)
Shape
Rods and Discs
Diameter
3/4"
Diameter Tolerance
±.002"
Length
12"
Length Tolerance
±1"
1/16" per 5 feet.
Tolerance
Standard
Test Report
Without Test Report
Condition/Temper
Annealed
Hardness
203 Brinell
Yield Strength
80,000 to 88,000 psi
Specifications Met
AMS Specification
AMS5648, AMS5653
ASTM Specification
Note
WARNING
Time :03
Search Terms: Socket Cap Screw:Stainless Steel:Standard:Plain:Type 316:inch:1/4-2-:3/4
Part 92185a540
Head Style
Standard
Standard Head Style
Standard
Material Type
Stainless Steel
Finish
Plain
Class
Not Rated
316 Stainless Steel
Drive Style
Hex Socket
Inch Thread Size
1/4"-20
Length
3/4"
Thread Length
Fully Threaded
Thread Direction
Right Handed
Tip Type
Plain
Self-Locking Method
None
Screw Quantity
Individual Screw
Hex Size
3/16"
Head Diameter
3/8"
Head Height
1/4"
Rockwell Hardness
B70
70,000 psi
Thread Fit
Class 3A
Specifications Met
Time :02Not Rated
argument 440:88
Ratio 5
5 * val<ETP> = 0.25
Match at Stainless Gauge 18 :0.05
Match at <cap screw head height> =.25
Quick ratio
argument 8:25
Ratio .32
0.32* val<ETP> 0.0160
Match at Stainless Gauge 28
Precision Warning***
< 95% confidence***(93.5 )
« Last Edit: November 10, 2012, 12:23:24 pm by jim miller »
Re: Meyer-Photo0066.jpg Photogrammetry
« Reply #1 on: February 08, 2011, 20:27:25 pm »
cool
