Author Topic: Demonstration Cell Abbreviations  (Read 1688 times)
« on: January 30, 2011, 12:27:10 pm »
last modified  19 2 2011 Added combining forms and moved basic list to the post from the attachment
To aid in discussions between researchers regarding the Stanley Meyer Demonstration Unit an excel spreadsheet listing standard abbreviations is attached for the major parts needed in demonstration cell replications.
For discussions regarding the tubes I suggest numbering the tubes clockwise starting with the tube nearest the viewer as tube set 1 and to the left of the midline of the of the photo or video clip
 I suggest that you download the Demo Abbreviation List.xls. version 8 file to your home computer, then add in whatever measurements, sources, part numbers and comments you have and then upload it the Demo Cell Replicator thread that Steve has started here at IonizationX under the Stan Meyers demo cell system heading.
As with any project there may errors of omission or commision. The photogrammetric process is dependent on having clear photos or videos which are sorely lacking  for some areas of the Demonstration Unit. A clear top-down view, bottom or a full length close up probably do not exist. Therefore there may be room for interpretation of some areas of construction and measurements.
Also for purposes of discussion use the McMaster part numbers. The part number leads you to exact specifications in their on-line catalog and can be a kind of "esperanto" for the replications. Many parts are, of course, available from alternate sources.
DEMO ABBREVIATION LIST Version 5
TCA WFC
Description
Standard
Abbreviation
PLUMBING Parts
Gas Nozzle Assembly
GNA
Gas Control Valve
GCV
Gas Exit Port
GEP
Gas Shut-off Valve
GSV
Gas Flow Valve
GFV
Gas Flow Gauge
GFG
Gas Pressure Gauge
GPG
Water Inlet Plug
WIP
Conical Gas Fitting
CGF
Gas Assembly Nipple
GAN
ACRYLICS
Tube Spacing Bar
TSB
Top End Cap
TEC
Botton End Cap
BEC
Support Base
SB
Support Base Rod
SBR
Cell Housing
CH
ELECTRICAL
Outer Tube 304L
OT
Inner Tuvbe 304L
IT
Electrical Transfer Plate
ETP
Inverted 7 Bracket
I7B
Inverted 7 Bracket Bolt
I7BB
Inverted 7 Bracket Washer
I7BW
Inverted 7 Bracket Nut
I7BN
Inner Tube Hex Nut
ITHN
Inner Tube Hex Bolt
ITHB
Inner Tube Split Washer
ISTW
Grounding Support Bar
GSB
Grounding Support Bar Washer
GSBW
Grounding Support Bar Bolt
GSBB
Grounding Support Bar Nut
GSBN
O RINGS
Top O Ring
TOR
Bottom O Ring
BOR
Bracket Bolt Seals
BBS
Grounding Bolt Seal
GBS
MISCELLANEOUS
Allen Head Cap Screws
ACS
Support Base Bolts
SBB
Support Base Cushion
SBC
Supoort Base Washer
SBW
Additions Corrections/Comments
Combining Terms
Number Designator 1,2,3 etc
H Height
L Length
W Width
ID inner diameter
OD outher diamter
ANG angle
Thus the inner diameter of the bottom o ring BOR is now called BORIDThe the outer diameter o fthe cell housing CH is now called CHODThe outer tube just to left of midline is now called IT1, the inner tube lust to right of midline is now called IT9 saves time in the discussions, of the SMDTR's It's a little more specific
I tried to implement Stan's concept of keep it simple stupid
« Last Edit: February 19, 2011, 12:54:05 pm by jim miller »
