Author Topic: Tubular Array Construction Detail of Labels for IITER p 28  (Read 1541 times)
« on: January 23, 2011, 04:39:41 am »
The purpose is to clarify the  hard to read labels from page 28 of the IITER
Diagram on page 28 of International Independent Test Evaluation Report
This clarification of labels of the Water Fuel Cell (Demonstration Unit
should put to rest the concept that the 3/4" inch tubes are  attached to a common 9 spoked plate (as per P. Kelley) The labels e1a and PL1 refer to the 3/4"inch tubes.The labels e2 and PL2 refer to the 1/2 inch tube. For purposes of illustration the side view has been shortened to fit on the page, but the other dimensions are to scale and the distance between the e1a bolts onthe bottom view match up with the side view distance between the bolts attached to the bent support brackets.
Exhibit E2: Tubular Cluster-Array
Clarification of Labels in Diagram
The Diagram Consist of Four Parts
1. Top View of the Tubular Assembly
2. Top View of the Perspex Cover
3. Bottom View of the Perspex Base
4. Side View of Demonstration Cell
 1.Top View of the Tubular Assembly
    (read labels in clockwise direction)
    ELECTRICAL TRANSFER PLATE (GND)
    PL1n    PL2n
    3/4" DIA x 0.35
    STAINLESS STEEL
    TUBE (PL1)
     1/2" DIA x 0.49
     STAINLESS STEEL
     TUBE (PL2)
     NON-OXIDIZING
     EXCITOR-TUBULAR ARRAY
     * 'Y
     (STAINLESS STEEL
     MAT'L SUCH AS T304)
     TOP VIEW
 2.  Top View of Perspex Cover
      fa
      WATER INLET
        PORT
      GAS OUTLET
        PORT
    TOP VIEW
        fa
 3. Bottom View of Perspex Base
        e2
        fa
        e1a
        e1a
        MOUNTING HOLES FOR
        SUPPORT-BASE * 'Y
        BOTTOM VIEW
        f-END-CAP
             MOUNTING BOLTS
        fa
     HIGH TEMPERATURE FLAME
        (VARIABLE CONTROL)
     GAS NOZZLE
         * 'Y
     GAS CONTROL VALVE
            (PRESSURE)
     GAS EXIT
              PORT
      GAS FLOW
            GAUGE
      "O" RING
         SEAL
       NATURAL WATER
           (NON PROCESS;
       NO CHEMICAL ADDITIVES)
       WATER CONTAMINATES
       LIBERATED DURING
       WATER/GAS CONVERSION
       ELECTRICAL TERMINAL
      e2          (D.C GND)
    SIDE VIEW
  PRESSURE RELIEF
                VALVE
 WATER INLET
    PORT  (PLUG-SEAL)
 NON-OXIDIZING
      HOUSING
 GENERATED GASES
   a.) HYDROGEN
   b.) OXYGEN
   c.) NITROGEN
     AND GASES
  TRAPPED IN WATER.
    NON OXIDIZING
   EXCITOR-PLATES * 'Y
    SIMILAR MAT'L
    SUCH AS STAINLESS
    STEEL T304
     (PL1/PL2)
            PL1
            PL2
     NOTE:
       STAINLESS STEEL
       * 'Y WITH STAINLESS
       STEEL ELECTRICAL
       TABS-T304 OR
       THE LIKE.
     e1-ELECTRICAL TERMINAL
         D.C. POSITIVE POTENTIAL
         CONSTANT ANODE PULSE)
     SUPPORT BASE
             * 'Y
NON-OXIDIZING MATERIAL CHARACTERISICS
  (material that does not oxidize under the
       following conditions)
1.) Material immersed in non-process/no chemical additives)
     natural water.
2.) Material immersed in non-process
     (natural) water while an low electrical
     potential(voltage at low amps) applied
     to said material.
3.) Material immersed in non-process
     (natural) water exposed  to oxygen
     atoms in said water.
4.) Material immersed in non-process
     (natural) water exposed to hydrogen
5.) Material immersed in non-process
     (natural) water exposed to both
     hydrogen/oxygen atoms in said water.
6.) Material immersed in non-process
     (natural)water exposed to both
     water while an low electrical power
     (voltage at low amps) is applied
     to said material.
 NON-OXIDIZING MATERIAL EXAMPLE
« Last Edit: January 31, 2011, 18:42:03 pm by jim miller »
