Author Topic: Area,Mass,Acoustics Rewrite  (Read 1554 times)
« on: January 21, 2011, 10:36:10 am »
This is where I'll be putting a more finished presentation.
As soon as I calculate and receive some new dimensions for the Demo Cell I'll put up an excel spreadsheet( under development) to put in tube material(type of metal) tube lengths, wall thickness, number, depth, and area of notches, method of attachment,temperature and then link it to an program that churns out expected acoustics. So send me
PMs or references in the patents,blogs then Ill crunch the numbers and see how close it is to your observed results
.But  dont tell me the frequency until I get back to you I want to see how good the program is without being biased.
I would be especially interested i for any one out there that actually saw, touched, measured or saw a patent reference to the length of the tubes used in the Meyer work.  For example where does Stan say that 27" is optimum?
Waterfuelcell.org forum, bing and google searches and google translate for the foreign sites. Many times I know I've seen the info but cant find it again  cant bookmark everything
Here's a starting point for the excell with the kind of info needed
but I'm more interested ithe actual physical cell construction than the electronics such as Cramton or Tony W's work which is spot on.
  http://h2earthlabs.netcipia.net/xwiki/bin/view/Main/WebHome
 or download a copy for modifiction or ideas of instrumentation
 Im not even sure the site is active so I wouldn't even try to post there but if you look at the email addresses of of the research fellows or search google by name of then you might be able to find some new materials such as videos, documents and ideas to aid your research or develop some new contacts.
« Last Edit: January 21, 2011, 11:04:09 am by jim miller »
