Author Topic: Tube Design The Equal Area Theory  (Read 1837 times)
« on: January 21, 2011, 03:23:45 am »
Modified 26 1 2011 added more Crampton info
Modified 30 1 2011 reconsidered with new length info
Ask the right question. Are the tubes in the demonstration cell being matched for Equal Area to match Capacitor Plate size or  are they being matched for acoustic reasons??
Meyers Demonstration Cell
The Meyer Demo Cell had an outer tube diameterof 0.75
The Meyer Demo Cell had an inner tube diameter of 0.5
The wall thickness of the outer tube was 0.035 inches
The wall thickness of the inner tube was 0.049 inches
The gap between the tubes was  .18 inches
The estimated size of the slots is .25 x 1 inch
The length of the outer tube has been given as 18 inches
The length of  the inner tube has been given as 19 inches
The length of the tubes may be as short as 13 and 5/16ths
New info released by Dynodon
The material used was 304 stainless
  see calc
.75- (2x.035) equals inner diameter of .68 inches Therefore .68-.5 =0.18 inch per inch of height of tube is the amount of material to be removed if equal area to be maintained.  If  the outer tube was 18 inches long ,then 18 squared/100 = 3.24 sq/in. This is the area of the notch that would be needed to maintain equal areas. See the Meyer Estate videos. If Stan was going for equal surface concept. the notch cut out is not even close to 3.24 square inches. (or maybe Stan did not make enough notches)
Revised calc based on 13.583 inches
13.583 x 18/100   = 2.94 square inches
Assume .25 x1 sq inch /slot,  2 slots= .5 sq inch  area match now closer
)Therefore acoustic tuning by notches is more likely than surface area match.(see Lawton comment on  notches)  This is simlar to tuning an organ pipe and Stan being a God-fearing man probably knew this from being in church and seeing the church organ........
Crampton Cell
The Cramton cell had an outer tube diameter of 0.75 inches
The Cramton cell had an inner tube diameter of 0.5inches
The wall thickness of  the outer tube was Calculable
The wall thickness of the inner tube is unk. presumes same as outer pipe
The gap between tubes was 1.2 mm
The estimated dimensions of the slots was 13 x 19 mm
The length of the outer tube after tuning was 445 mm
The length of the inner tube was  18 inches or 450mm
The material used was Stainless Steel 316L
Clamps and attached Z brackets and are factored in and adustment are made in the outer tube length to account fot this increased mass  which affect the  outer pips audio frequency in air. He gives a link to free audio tuning software
Total Area of outer surface of inside tube
CxPiXL 0.5(3.1416)(18) = 28.27 sq inches
Total Area of inner surface of outer tube assuming 1. mm gap
Volume of metal for outer tube was    cubic inches
Volume of metal for inner tube was    cubic inches
Volume of metal for outer tube with slots       cubic  inches
Volume of metal for inner tube  overlapping slotted tube
What is the ratio of mass between inner and outer tubes?
What is the ratio of mass between inner and outer tube  overlapped
What is the ratio of mass between inner and outer tubes after adjusting for slots?
Is the the amount of mass removed for the slots sufficient to match up the masses of the the two tubes?
How big would the slots have to be to match the tubes in terms of mass?
If the bottom of the slot is the new acoustic length, how many slots and what dimensions will remove sufficient mass to match the mass of the inner tube?  Use multiple slots to remove sufficient mass to match the tube set acoustically
( seeLawton comment regarding length of slot0
Let L =length of slot let W = the width of the slot or sigma the
all the slots assume same depth. Then L times the W (% of circumference) x weight for  1 inch of tube.  is the cubic inches of metal removed for a slot  angle/360 So now use the new value
 of L....... ( this is getting  complex ..................lets say that  half the tube is removed as a slot  180 degrees  and is 2 two inches deep
then the weight removed will be the same cutting off 1 inch of tube.  if the slot was 1/3 of the circumferece of a one inch tube
120 degrees and 1 inch deep the mass removed would be 1/3 the mass of a 1 inch section of tube. Therefore if  you want to make  the masses match you need to solve an equation that removes sufficient metal with notches to make the tubes equal in mass and acoustically the same.or VARY THE WALL THICKNESS, DIAMETER, AND LENGTH to maintain the proper gap, area overlap and weight per tube allowing for small notches or slots
to make small adjustments. Lawton "it has been suggested that the depth of the slot.."  All of the above discussion assumes that the bottom of the slot is the new acoustic length. Actually if that were the case then cutting off one inch of a tube would remove the same mass as a 180 egree slot 2 inches deep but the acoustics will be different.
« Last Edit: February 05, 2011, 06:49:59 am by jim miller »
Re: Tube Design The Equal Area Theory
« Reply #1 on: January 31, 2011, 00:28:09 am »
some of the outer tubes were .030 thick,and some were .049 thick.Two different thicknesses!!!
« Reply #2 on: January 31, 2011, 01:09:27 am »
The tube in question is OT8, numbering counting counter- clockwise with tube 1 being the one closest to the observer that is left of the midline of the photo. Clearly the outer tube has a dimension that is that is greater that most of the other tubes.
I had guessed previously that it was in the 0.40 to 0.049 range
so thank you for confirming the measurement. This discussion has nothing to do with electronics. It is only an observation that
OT8 has a wall thickness greater than all the other outer tubes
and that 7 of 8 other the remaining tube sets have an inner tube
longer than the outer tube, but tube set 8 TS8 has a shorter tube.
 It might be just be coincidence.If I had a top down shot of the tube sets the photogrammetrics could clarify the outer tube thicknesses. As it stands right now, the beveling that Stan did on the tubes makes if difficult to determine wall thickness at such an oblique angle. TS2 is the other tube that has a shorter inner tube. Could just be a random thing. But in terms of acoustics only ,I feel it needs more investigation.
