Author Topic: Winding a torroidal core  (Read 3276 times)
keithturtle
« on: February 08, 2008, 01:31:12 am »
Pneu engine wants me to wind a few torroids fer 'im, and gave a suggestion that sounds plausible.
I always feared the task, fer the last time I had to wrap only 17 turns thru an auto-transformer, I had 25' of wire stretched across the shop floor, pullin' it all thru one wrap at a time... yuck.
Anyhow, PE told me to spool the required length onto a dowel that would fit thru the center hole, allowing for the finished built-up thickness.
Wow... could it be that simple?  Trying it now with a small core and will post pics and results some time next week
Turtle, still building
Re: Winding a torroidal core
« Reply #1 on: February 08, 2008, 12:16:41 pm »
Keith,
all the best with winding...lol
you can also choose a bigger torroid with a bigger hole.
PE gave a nice advice too.
The winding jobs are always the most nasty to do.
steve
oddball
« Reply #2 on: February 08, 2008, 15:08:19 pm »
Yes I did about 600 winds on a 2" toroid last week and it took about 4 hours :(
hydro
« Reply #3 on: February 08, 2008, 16:16:29 pm »
i'll just tell ya, if you're going to make that transformer in the meyer patent it dont work, you will get bubbles but that all you'll get.
i used a broke pencil and wrapped my wire around that, i then passed that threw the core, worked fine, about 3 mins, oh, i also sit the small core onto a large magnet to help hold it. the primary i used 100 wrapps, if you choose to use 200 wrapps on the primary atleast center tap it on 100 wrapps.
keithturtle
« Reply #4 on: February 14, 2008, 06:07:52 am »
Magnet- WOW, and I was makin' acrylic jaws to do the same- thanks, man!
Turtle, saving time
