Author Topic: Bob Boyce  (Read 42589 times)
Bob Boyce
« on: February 04, 2008, 15:01:16 pm »
Hello,, After Living with and testing the alternator over a period of time great knowledge grows on you.
i have found the reason my alternator setup really works so well, it is because it uses 3 phase Harmonics, very much like the harmonics that opera singers use to break glass, but this type of harmonic that bustes water found by the alternator and bob boyces setup is intermingled, or 3 in 1.
to who does not build the alternator, atleast build the bob boyce circuit! Here is the link., http://pesn.com/2007/09/29/9500450_BobBoyce_Electrolizer_Plans/d9.pdf
Bob Tuned into the Harmonic Resonate Frequency Of Water!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
just like we did with the 3 phase harmonics from the alternator.
Harmonics is used to break things, and the high gas output i seen inside my cell did not come from amps and volts people, there was something else causing this high gas yield, "THE RESONATE FUEL CELL" where the harmonic waves causes the Water Molecule to Break Just like the opera singer causes the Glass to shatter.
The Resonate fuel cell is now understood(bob boyce) and Has been understood(bob boyce) and OVERLOOKED by ME  for a long time now. after realizing why the alternator works so good, and comparing that to BOB BOYCE system, IT IS CLEAR ALL YOU NEED IS RESONATE!!!!!!!!
Anyone to work with Any resonate type cell please post your info here, 2008 brings to us a new year of understanding what is really going on here.
« Last Edit: February 04, 2008, 15:06:11 pm by hydrocars »
kumaran
Re: Bob Boyce
« Reply #1 on: February 05, 2008, 03:30:53 am »
Hi hydrocars,
I did test the 3PH resonance drive circuit before but didn't measure gas output. I find it's a bit hard to tune the right frequency in three phases and ended up with blowing mosfets. I will go back to this circuit once I got some free time. I suggest you guys focus along this direction and probably can get results faster since the method already tested by Bob Boyce. There must be some hidden secret Bob never release to public.
If some effort put into this line, I'm confident that you guys can break the rule. Frequency 10.7kHz, 21.4kHz and 42.8kHz. Happy experimenting.
Re: Bob Boyce
« Reply #2 on: February 05, 2008, 15:35:52 pm »
nice info guys, well im not sure if the circuit works with or without electrolite, in the pdf link i posted it tells you, i just forgot. I NEVER USE ELECTROLYTE! I NEVER HAVE, i have used salts for test, but maybe 2 or 3 times.
the alternator is resonating with the fuel cell. you do get free hydrogen when you hit resonance, apararently the 3 phase harmonics does just that, but its not alot of free hydrogen it should still be taken to the next level.
im not sure if stan woke up one day and said hey, i want to hook my cell to a alternator to get 3 phase harmonics to super bust the water? or if he hooked it up by accident and seen that the harmonics could be used to cause a tremendous gas output and quickly forgot about the alternator and started on resonate frequencys.
we should take this further.
kumaran
Re: Bob Boyce
« Reply #3 on: February 06, 2008, 04:52:18 am »
Would you say the main differences between your alt. set up and boyce's schematics is boyce uses an electrolite such as koh and you use just water?  I've haven't seen any post where you use an electrolite.
Keep it simple. What ever information related to Bob Boyce method uses electrolyte (28% KOH) and what ever information related to Stan Meyer does not use electrolyte (just tap water with little conductive). I'm using Bob Boyce method now.
oddball
Re: Bob Boyce
« Reply #4 on: February 06, 2008, 15:03:29 pm »
It looks like we are all thinking about using 3 frequencies now.
So do you think a 6 plate series cell should be used on our 12 V systems?
Boyce also says 1.5 V per cell for a resonant system so hence Kumaran with his 8 plates.
His system uses a plate cell like the ZooFFer cell http://www.youtube.com/watch?v=QpQHIO2kw58
I had a go at winding a 2" TORROID with 30 metres of wire at the weekend and it took 4 hours to make a 2 to 1 ratio transformer. 10 metres primary and 20 metres secondary winding. I am not so impressed with the results of the transformer yet so intend to try the CCT output direct to the cell at first.
« Last Edit: February 06, 2008, 16:37:15 pm by oddball »
Re: Bob Boyce
« Reply #5 on: February 11, 2008, 05:18:55 am »
I found someone on ebay selling a Bob Boyce PWM3G Electrolyser Kit c/w PCB
(http://i23.ebayimg.com/02/i/000/ca/cc/3969_1.JPG)
Would ya'll recommend this?
Re: Bob Boyce
« Reply #6 on: February 11, 2008, 11:37:42 am »
what are the critics on this ebay seller?
If they are good, and you wanna make a Bob circuit...and electrics is not yr best point....
I would say go for it..unless the price is sky high.
keithturtle
Re: Bob Boyce
« Reply #7 on: February 13, 2008, 08:26:54 am »
I'm in the process of assembling a large cell with two rows of 61 plates, 6" x 7" 14 ga, but they're 304, not 316 SS.
Cross sanded one batch, but I think I'll polish the other set to compare.
ALready got the UHMW milled, but it bowed so I gotta relieve the back side.
This is heavy-duty stuff, with heavy duty turtlebucks spent so far.
It all takes lotsa time.
Turtle
