Author Topic: Self Resonate Wfc  (Read 10407 times)
Self Resonate Wfc
« on: January 21, 2008, 09:16:48 am »
here is a new birth, the circuit is untested and thrown together.
you can perform a small test, hook your cell to the mot while holding both wires in your hand, then unhook the cell from the mot while still holding the mots secondary wires in your hands. you will feel a not to nasty shock.
hook a led to your wfc, notice what happens.
hook a led to your mots output in the proper direction, then arc your cell to the terminals then release, notice what happens.
the MOT SHOULD NEVER EVER BE HOOKED TO THE WALL OUTLET, this circuit Does not use ANY external power and is untested.
for best results perform electrolysis with a 12 volt battery.
again, this circuit is untested.
Warning, when using mots you only get to make one mistake before your dead, THE MOT IS NOT CONNECTED TO ANY SORT OF EXTERNAL POWER EVER
« Last Edit: January 21, 2008, 09:20:03 am by hydrocars »
Re: Self Resonate Wfc
« Reply #1 on: January 22, 2008, 03:17:07 am »
It has been confirmed that you can extract more electricity from the device hooked to the fuel cell than you can extract from the fuel cell itself! !
more energy was produced from the device the cell was hooked to than the cell itself was capable of producing. the produced electricity should be redirected back into the fuel cell from the electron extraction device to fuel the fuel cell even more.
Test proves and shows that an infinite amount of resonation between the device and the cell is possible in this world.
the above circuit is the analog Beta circuit and was not used during testing allthough it functioned in the same manenr as the circuit above, the mot coil was used for this test.
« Last Edit: January 22, 2008, 03:24:29 am by hydrocars »
« Reply #2 on: January 22, 2008, 04:05:50 am »
it has been 1 hour 8 mins and the led is getting dimmer.
« Reply #3 on: January 22, 2008, 04:48:45 am »
it has been almost 2 hours and still the way it was when i last replied, this could go on all nite?
« Last Edit: January 22, 2008, 04:51:07 am by hydrocars »
« Reply #4 on: January 22, 2008, 09:59:10 am »
Hi hydrocars,
Can you perform a test with this new setup that you charge thw wfc big time and see what you get out the led or lightbulb?
« Reply #5 on: January 22, 2008, 11:01:03 am »
thats what i did stevo,, charged the cell then let it power the bulb.
« Reply #6 on: January 23, 2008, 14:07:13 pm »
Ok, this could be major!
Meaning, we put power in and in the pulse off time we take some power out and re-use it!!!!
People, lets go. This it!
« Reply #7 on: January 23, 2008, 22:09:17 pm »
Today I confirmed the results of Hydro
It means that a Led was light from the WFC.
You need a coil to do so.
I have to think really deap about this thing.
What did Stan the man called his chokes?
A resonant CHARGING choke?
