Author Topic: Stan's Resonant Frequency  (Read 43581 times)
0 Members and 20 Guests are viewing this topic.
Re: Stan's Resonant Frequency
« Reply #96 on: January 10, 2011, 20:47:39 pm »
Hi Andy,
I took an old microwave oven transformer and I'm only using the secondary side of it. I took the secondary and divided it in the middle and then cut the wire in the center to make it two separate coils. I think is its hooked up field aiding but not 100% sure cuz its really hard to tell by the way the secondary in wound. Hope this answered your question. Im gonna order a spool of copper wire and wind my own coils and re-test. Hopefully I will have a lot better results with higher voltages.
« Reply #97 on: January 12, 2011, 13:05:26 pm »
this is not too bad of an example of what takes place in the Stan's LC circuit. Once resonance is achieved on the secondary side the impedance is so high on the primary side that it limits current in the main circuit. This is basically what has to take place in WFC!!!  As you can see this is whats taking place in my testing of the 8XA circuit, this is why I can only get a max voltage input of around 10v to the chokes and the output voltage of the chokes is over 400v.
Hello, you attach your project
 PLL circuit?
 Thanks
Riccardo
« Reply #98 on: January 13, 2011, 20:46:45 pm »
no haven't got the PLL together yet, hopefully I will have a complete circuit put together soon.
« Reply #99 on: January 14, 2011, 11:38:09 am »
Many Thanks !!
Ciao ;)
« Reply #100 on: January 15, 2011, 23:04:32 pm »
Hi Tony,
I made it to work. Thanks.
Now up to higher voltages.
http://www.ionizationx.com/index.php/topic,1844.new.html#new
« Reply #101 on: January 15, 2011, 23:53:27 pm »
Glad to see that someone else has been able to replicate and confirm what Ive done :-)
« Reply #102 on: July 20, 2011, 08:09:47 am »
hey are my component values.
(http://www.globalkast.com/images/tonywoodside/8XA_component_values_power_supply.jpg)
(http://www.globalkast.com/images/tonywoodside/8XA_component_values_pulse_generator.jpg)
(http://www.globalkast.com/images/tonywoodside/8XA_component_values_vic.jpg)
Please note for a moment where Stan has his volt meter showing this "high voltage" and what effect the choke will do to this voltage before the cell.
Still reading through this thread.
« Reply #103 on: July 20, 2011, 14:56:18 pm »
theres one thing I see that could do with a modification to stans circuit above - its fed with an ac power supply, stipulated at 60hz, the rectified side labelled a unipolar voltage waveform. When in use in a vehicle it appears to me that the dc supply be driven by a waveform to produce the unipolar voltage waveform. imho of course.
