Author Topic: Stan's Resonant Frequency  (Read 43585 times)
0 Members and 20 Guests are viewing this topic.
Re: Stan's Resonant Frequency
« Reply #88 on: January 09, 2011, 21:28:55 pm »
Awesome work
What happens when you short out the output and create the dead short condition?
« Reply #89 on: January 09, 2011, 23:47:32 pm »
current starts to flow through the system and resonance is lost, so basically becomes normal electrolysis.
« Reply #90 on: January 10, 2011, 01:50:12 am »
Tony, the resonant signal that you posted has renewed my intrest in this project.  I built some figure 6-1 Vic-coils (plug & play) a couple of years ago using the SS wire for chokes.  The wire had an inadequate insulation and shorted out in the coils I produced.  I did obtain 5lbs of the 430fr ss wire from dynodon out of Stan’s surplus but never built a coil with it due to my disappointment with the multiple coil failures prior to obtaining it.   I saw your post requesting a 3” tube cell set and I do have a few ½” and ¾” ss tubes I would give you if you want them.  I’m posting a picture of the coil I built.
« Reply #91 on: January 10, 2011, 02:58:40 am »
430fr ss wire
http://cartech.ides.com/datasheet.aspx?i=103&e=63&c=techart
Some information on the wire
« Reply #92 on: January 10, 2011, 03:12:08 am »
Interesting Video on Reasonance
Energy Propagation
« Reply #93 on: January 10, 2011, 03:32:23 am »
this is not too bad of an example of what takes place in the Stan's LC circuit. Once resonance is achieved on the secondary side the impedance is so high on the primary side that it limits current in the main circuit. This is basically what has to take place in WFC!!!  As you can see this is whats taking place in my testing of the 8XA circuit, this is why I can only get a max voltage input of around 10v to the chokes and the output voltage of the chokes is over 400v.
« Reply #94 on: January 10, 2011, 07:12:24 am »
« Reply #95 on: January 10, 2011, 19:45:11 pm »
Hi Tony
I have question for you. Are your chokes bifilar wound? And are connected with aiding or opposing field?
Your quote:
 I have it connected just as in the schematic. The chokes are bifilar wound on a single core and measure just over 2H each. I retested my setup and I get a max voltage across the cell of just over 400VAC RMS (1132V peak-to-peak) while applying 10V full-wave rectified (120Hz) DC pulsed at 2.296kHz. The current measured is 58mA, so the Power input is just over 1/2 a watt, 0.58W.     Thank for answer
andy
Tony sorry if my question is so stupid .
« Last Edit: January 10, 2011, 20:15:10 pm by andy »
