Author Topic: Bob Beck magnetic pulser  (Read 8433 times)
« on: November 03, 2010, 23:47:58 pm »
I build the magnetic pulser from two very usable websites:
Chris Gupta
http://www.newmediaexplorer.org/chris/2003/08/19/build_a_low_cost_simple_magnetic_pulser.htm
TwoTowers
http://www.twotowers.com/beck/beck_emp.html
I used all the components out of my part box except for the coil that I ordered in Germany.
http://www.hifi-zubehoer.com/?sessionnr=GHxcket0ZlCzFJE1PxYA&sessionid=3572448
Here the schematic with my own modifications (in red) with no reasons, I wanted to get close to the schematic of Chris and see if it works. I also looked at this online coil generator to see if I get close to the results of the original schematic which is also a replication of Bob Beck, not the patent I think. http://www.coilgun.info/mark2/rlcsim.htm
(http://www.sumopaint.com/files/images800/axxdbxizgrkiccck.jpg)
(http://www.sumopaint.com/files/images800/axxdbefzoqcrpikj.jpg)
I have build in a heatsink with a small cooling fan which is fed by the black 220v to 12v transformer at the front. I don't know if this was necessary but I just want to protect the thyristor for overheating.
(http://www.sumopaint.com/files/images800/axxdbfgzxclepdpt.jpg)
The capacitors charges around 322volt in 6 seconds. So I wait between the pulses.
(http://www.sumopaint.com/files/images800/axxdbhazimnjhnpd.jpg)
I pulsed my two legs to kill a nasty ringworm infection, lets see what is going to happen. I have to read  more over the use of this device. On this moment I use also the blood electrofier and colloidal silver water.
Re: Bob Beck magnetic pulser
« Reply #1 on: November 04, 2010, 03:56:16 am »
so we have an ac power source, light bulbs for resistors, a diode to rectify, capacitors to charge, a thyristor and push switch to discharge the capacitors into the coil
simple enough
i would guess that values don't have to be terribly specific, different values would just give different strength magnetic fields
we want a small resistance in the coil to make a large current em pulse
« Reply #2 on: November 04, 2010, 21:44:29 pm »
Yea it is all very simple. I think I have not the good capacitors, they recommend fast charging ones. When I hold down the orange fire button, the pulses starting to repeat automatically, but the capacitors do not have enough time to charge so the pulses are weak. I get only a strong pulse by waiting for 6 seconds and then fire again. I have some capacitors left over from some flash camera's. I make a second capacitor bank and see how it works.
« Reply #3 on: November 04, 2010, 22:48:37 pm »
I put in the new capacitor bank. The voltage climbed a slightly to 330v but the charging does not go any faster. Let do some reading.
