Author Topic: 102 plates drycell  (Read 32396 times)
Re: 102 plates drycell
« Reply #48 on: June 19, 2010, 22:56:39 pm »
someone else trying to replicate: http://www.overunity.de/index.php?topic=627.msg10628#msg10628
Thanks Haithar.
I just orderd the zahnrader from Conrad in the Netherlands... ;)
Then i can make the same gearbox as Sante did.
regards
« Reply #49 on: June 20, 2010, 18:56:28 pm »
sorry for the stupid question, but would you have to modify a two-stroke engine too? or only four-stroke engines?
  • Yes I got Jolted,
« Reply #50 on: June 20, 2010, 19:04:15 pm »
You don't need to mod the spark on a 2 cycle engine. you do need to add oil for lubrication.
2 cycle engine need oil mixed in the gasoline.
« Reply #51 on: June 20, 2010, 22:41:32 pm »
i agree with Jolt.
You need some oildrops to save your engines life.
regards
Re: 102 plates drycell modification of the iginition system
« Reply #52 on: June 24, 2010, 23:01:16 pm »
Gears are in.
I went to the metalshop to extend a bolt so i am now able to mount the smal gear on it.
See picture.
regards to you all. The Netherlands won the third soccermatch   :)
Re: 102 plates drycell, new iginition system
« Reply #53 on: June 29, 2010, 00:02:04 am »
Hi folks,
Here a schematic that i will use on my genset.
All components can be bought at Farnell.com
regards
« Reply #54 on: July 03, 2010, 11:38:43 am »
which material do you use between the plates as a waterproof seal?
also how do i clean the plates after having cut holes in them? i suppose soap or other cleaners aren't good when using them for electrolysis later? :/
« Reply #55 on: July 03, 2010, 13:23:34 pm »
The most simple and cheapest gaskets that i use are made from flexible PVC.
I buy it by my local store that sells large sheets for:
Teich Pfütze Tümpel for fisches in your garden... ;)
Not sure what the right german word is.
In English it is called a pond. In my country they say: vijver
The thinkness i use now is 1mm. It is similair as the Anton guys do. But that is just coincident.
I used in the past 0.5mm, but with my current material is found out that 1mm is better.
Make your gaskets as small as possible to maximize the use of your plates.
Last tip:
All holes in your plates MUST be out of synch of eachother.
Thise prevents leakage of current and makes your cell 10% more efficient.
What most people dont know is that sanding your plates help.It makes a larger surface on micro level.
About cleaning: if you use NAOH or KOH then you can be sure that your plates will be cleaned!
Hahahahaha.
If you rinse the plates proper after sanding should be sufficient.
Try not to touch the plates after the sanding.rinsing with your fingers.
Thats all.
regards
