Author Topic: 102 plates drycell  (Read 32383 times)
Re: 102 plates drycell
« Reply #24 on: May 25, 2010, 21:24:54 pm »
There is only one crack on which you can mount something.
Wel, i like the 2 gear solution. But there are no gears sofar on the net that are usable. Maybe i must look for a bicycle orso....
« Reply #25 on: May 25, 2010, 22:15:26 pm »
I know you are looking for gears but since I really havn't seen what you are dealing with another approach that may be cheaper than gears just for a test may be using pulley's and belts.
Also I saw a video somewhere, where the guy made his gear wheel from a piece of wood.
Its possible to make from plastic.
Just suggestions if you run out of things to try.
« Reply #26 on: May 26, 2010, 14:28:23 pm »
If you can figure out where the camkshaft is situated from a workshop manual or somethiing; perhaps it may be simplest to machine a hole in the casing at the camshaft's end.   Fit a seal and extend the camshaft.
I also dont see a normal fan-belt slipping with such a tiny load on it.
It would also give you the ability to set the timing easily.
« Reply #27 on: June 12, 2010, 16:22:05 pm »
how's it going with this?
The Anton cell team said while the video is only 40 seconds long they cut it. The engine ran longer than that.
Also they claimed 10 people have visited them in the last month and seen it with their own eyes.
do you make any progress?
« Reply #28 on: June 12, 2010, 16:51:23 pm »
I think that here is a misunderstanding with those anton boys.
I have not read anywhere that their generator was providing the power for the anton cell.
Progress: drycell is ready. Bublers are ready. Only the genset.........
« Reply #29 on: June 12, 2010, 17:43:07 pm »
No no, that's exactly what they claim.
« Reply #30 on: June 13, 2010, 00:13:19 am »
Haithair,
I couldnt find it anywhere....
