Author Topic: My new Garage(Lab) Let the party begin !  (Read 6219 times)
Re: My new Garage(Lab) Let the party begin !
« Reply #8 on: May 20, 2010, 01:04:33 am »
All you need:
« Reply #9 on: May 20, 2010, 22:35:50 pm »
You have a nice collection, HM.
If you read that document of Stan from Donald, then it must be pretty easy to make a resonant setup doing gallons of water in one hour.
I still wondering why NOBODY ever made a working setup.....
« Reply #10 on: May 21, 2010, 03:58:03 am »
Because the first thing to do is get voltage across water.
Then when you gain the voltage, You are far from done!!!!
Then, the voltage has to be tuned, Just as the microwave oven got its name from the "Microwaves." If Xray boiled water we would call it a Xray machine, But thats not the case.
Anyways, This technology will take great effort in the "Dark" without the million of dollars worth of equiptment needed to analyze each and every test, We simply do not have those tools.
However, We begin to understand how its working, "We now have a chance working in the dark."
I've shown how to gain voltage Potential across conductive water, I have no clue how to show how to "Tune" this potential Fields to the water, That is the next step, the atomic level.
However, Stan ran his car on a 3 phase gen, Not this super Star Force technology, However there is No reason whatsoever why Voltage potential wouldn't do the job, It works for heating the water which is a form of work, It can also pull it apart. At no angle will it be free But different It will be, Not normal electrolysis.
No Replications;
Nobody has the proper sense to tune voltage potential to water, I was hoping to see lots apply the potential across the water, Then later watch them "Later" try to tune it after they realized they had the needed voltage. However the Proof of my findings has stalled, You can take my word for it, Or simply wait for donaldwfc to confirm it, Which he may/maynot.
The choke I sent him is Indeed special, And only 1 choke is needed, But it is unclear how anything has been confirmed or not confirmed. The main point is we got the gained voltage across the conductive water and we know this without doubt, Now it must be tuned on the atomic level,
On such a level many can not coop with.
Know what you are doing.
1. focus on what your goal is.
2. Slowly take your time and fullfill your goal, the setup.
3. Test the setup, if something is wrong find the solution.
4. get the setup to show promising signs, even if it doesn't do what its intended to do.
5. Now you have a setup promising, Slowly take years from your life to tune it.
6. Spend time thinking how you might could better the setup, what you may need to do here or there.
7. Spend more time on the Atomic level, "If you're a technology Geek."
If you just want to run a car on water, "This is not the way to do it." Use Current flow for that, Lots of it. As stan did with the 3 phase gen.
If you want to Crack a new technology, spend your time on the vic, on the atomic level.
Stan did not run his car on the Vic, He did not run his car on the atomic level, Only normal electrolysis with very clever setups. However stan has a very good point about voltage potential, And one day it will rule this world. Once its cracked hydrogen will be abundant.
Everyone here is confused. Ask yourself,, What is your goal?????
is it;
1. Abundant unnormal electrolysis? If so do the vic "Cracking a new technology would be your goal."
2. Running a car on water, If so, do this with normal electrolysis. "Cracking a clever setup wb your goal."
What is your guy's goal, this is your direction. Mine was is both. Trust me, I'm thinking and not doing..
Are you a doer? No affense, But god was a doer, Atheist please overlook that as it is only to make good point.
« Reply #11 on: May 21, 2010, 08:07:37 am »
Thaks for the tips Warp. My interest here is only in splitting water  by voltage. Not normal electrolysis.
I hope to find out what is the more efficient.
« Reply #12 on: May 23, 2010, 10:59:45 am »
Yes don, I am going to start everything step by step and publish results on this forum.
hmask
