Author Topic: New DC resonant charging circuit  (Read 15117 times)
Re: New DC resonant charging circuit
« Reply #8 on: April 09, 2010, 08:41:14 am »
add a series resistor some where? might need a big one though
a coil perhaps as resistor?
« Reply #9 on: April 10, 2010, 11:21:50 am »
Why is it that current goes up dramatically if i put a flyback diode anti-parallel to the coil in this circuit?
Same is when i put a diode parallel to the transformer, the current isn't frequency dependant anymore, without diode: 30V / 0,3A. with diode: 3V / 1A (1A limit from power supply). i don't get it.
anyway, problem solved. without the diode current draw is small.
« Last Edit: April 10, 2010, 12:04:56 pm by haithar »
« Reply #10 on: April 11, 2010, 13:37:24 pm »
here a new Stan based setup.
The voltage across the cap charges higher then applied voltage.
The resistor is for leaking charge, but cannot simulate a WFC perfectly...
Cap and coil and frequency match.
The result is that amps and volts are 180 degree out of phase.
Hmmm, who said that his system was working with 180 degrees phase difference between volts and amps?
yes STAN MEYER...
$ 1 5.0E-6 0.23009758908928252 51 5.0 50
c 416 240 416 320 0 1.0E-8 21.46768997989414
r 480 240 480 320 0 3806.0
w 208 320 320 320 0
w 416 240 480 240 0
w 416 320 480 320 0
d 208 240 240 240 1 0.805904783
l 240 240 288 240 0 0.01 -1.2134390714457766E-15
w 320 320 416 320 0
w 288 240 416 240 0
v 144 320 144 240 0 0 40.0 36.0 0.0 0.0 0.5
w 144 320 208 320 0
159 208 240 144 240 0
R 176 224 176 128 0 2 15500.0 5.0 0.0 0.0 0.5
o 0 1 0 35 61.23604138321678 0.03827252586451049 0 -1
o 9 1 0 35 40.0 0.1 1 -1
o 1 1 0 35 69.99202319305638 0.02187250724783012 2 -1
« Reply #11 on: April 11, 2010, 14:14:43 pm »
Why does it work in a simulation but not in reality  :-\
c 416 240 416 320 0 1.0E-8 700.655449046733
w 416 240 480 240 0
w 416 320 480 320 0
l 240 240 288 240 0 0.01 -1.3877787807814457E-17
w 320 320 416 320 0
w 288 240 416 240 0
v 144 320 144 240 0 0 40.0 360.0 0.0 0.0 0.5
w 144 320 208 320 0
R 176 224 176 128 0 2 3000.0 5.0 0.0 0.0 0.5
w 208 320 320 320 0
o 0 1 0 35 979.7766621314685 7.475102707912206E-5 0 -1
o 7 1 0 35 640.0 9.765625E-5 1 -1
« Reply #12 on: April 11, 2010, 17:22:00 pm »
w 416 240 480 240 0
w 416 320 480 320 0
w 320 320 416 320 0
w 288 240 416 240 0
w 144 320 208 320 0
w 208 320 320 320 0
I hope to give it a shot this week...
« Reply #13 on: April 11, 2010, 18:37:44 pm »
c 416 224 416 304 0 1.0E-8 -1.2675553006208302
w 416 224 480 224 0
w 416 304 480 304 0
d 208 224 240 224 1 0.805904783
l 240 224 288 224 0 0.01 -1.7763568394002505E-15
w 320 304 416 304 0
w 288 224 416 224 0
v 144 304 144 224 0 0 40.0 360.0 0.0 0.0 0.5
w 144 304 208 304 0
159 208 224 144 224 0
R 176 208 176 112 0 2 3000.0 5.0 0.0 0.0 0.5
w 208 304 320 304 0
A 144 304 48 256 0 0 40.0 5.0 0.0 0.0 0.5
g 416 224 416 128 0
o 0 1 0 35 979.7766621314685 4.898883310657343 0 -1
« Reply #14 on: April 11, 2010, 20:51:46 pm »
w 416 224 480 224 0
w 416 304 480 304 0
w 320 304 416 304 0
w 288 224 416 224 0
w 144 304 208 304 0
w 208 304 320 304 0
g 416 224 416 128 0
Brian,
You added an Antenna towards your schematic.
Can you explain why you did this?
« Reply #15 on: April 12, 2010, 09:08:53 am »
$ 1 5.0E-6 2.922428378123494 57 5.0 50
T 224 224 288 224 0 1.0 20.0 85.16743026114969 -4.253913238796301
R 224 224 128 224 1 5 1000.0 12.5 2.5 0.0 0.5
g 224 256 224 288 0
d 288 224 320 224 1 2.0
w 320 224 368 224 0
l 288 256 368 256 0 1.0E-6 -19152.689663265097
w 368 224 400 224 0
w 400 224 432 224 0
w 368 256 400 256 0
w 400 256 432 256 0
c 400 224 400 256 0 0.0010 172.38628755085708
r 432 256 432 224 0 78.8
w 432 256 480 256 0
w 432 224 480 224 0
i 480 256 480 224 0 0.0050
g 288 256 288 288 0
A 400 224 400 144 0 0 40.0 5.0 0.0 0.0 0.5
o 10 32 0 43 1197.2621413014756 24519.928653854222 0 -1
