Author Topic: The truth on how to run your engine on a Waterfuelcell  (Read 15459 times)
Re: The truth on how to run your engine on a Waterfuelcell
« Reply #16 on: March 23, 2010, 17:41:10 pm »
alright, thanks.
i thought the explosions weren't continuous but precisely timed when the piston is at the right position.
« Reply #17 on: March 24, 2010, 00:42:49 am »
Why do you want to lower the burning velocity in complicated ways instead of altering the spark plug, so that the position is right for instantaneous burning instead of the delayed gas burning?
Because the explosion of hydrogen in stochimetric mix with oxygen is like PFF and no piston got the time to move downwards
Petrol does like this: PFFFFFFFFFFFF. Enought time to start moving downwards and thats what we need.
Thats why you need a slower explosion.....
Stan spoke some on dvd about how the ambient air didn't support a flame, he stated that he used that to slow down the burn rate, and that he could go as low is a piece of paper burning if he wanted because of the non combustible support of the ambient air.
I haven't read the previouse post of this thread, just thought id drop in and respond.
« Reply #18 on: March 24, 2010, 00:51:28 am »
Ok, I went over the first of the thread.
As you all know I had a big claim of ionizing the hydrogen and oxygen, And I failed misserably at replicating it. Later on I finally figured out what I did wrong. When I went to post my findings, As usual it was debunked and overlooked.
I have put an entirely lot of effort, and time into describing how to properly do it, But again its overlooked. I've posted instructions time after time, Still nobody listens.
It is possible you don't have to have any ionizer to alter the gas. In fact, I posted instructions on how to do it about a week ago, And still to this day it is overlooked.
Perhaps eventually somebody will stumble upon how to do it, The realize all this time I already had it posted right in front of your face.
« Reply #19 on: March 24, 2010, 09:19:12 am »
Warp,
Can you explain yourself?
Just a short, plain suggestion on how you would get electrons into the gasmix?
« Reply #20 on: March 25, 2010, 00:13:12 am »
Warp,
Right off the top of my head,
http://www.ionizationx.com/index.php/topic,1338.msg15047.html#msg15047
http://www.ionizationx.com/index.php/topic,1201.msg12616.html#msg12616
http://www.ionizationx.com/index.php/topic,1201.msg12676.html#msg12676
Most of what i've posted was under my old name which has been deleted.
robertmoore
« Reply #21 on: August 24, 2011, 08:46:27 am »
Using waterfuelcell with engine has many important advantages such as its helps in reducing pollution, it has greater efficiency then diesel and gas engines and as compared to other engines they are quite silent.
« Reply #22 on: August 24, 2011, 09:21:34 am »
Yes, indeed sir.
Thats the purpose of this forum.
To change the world from fossil till water as fuelsource.
brookeross
« Reply #23 on: November 21, 2011, 07:03:02 am »
Does run a car on water really work?
