Author Topic: marko rodin explaining his rodin coil  (Read 20026 times)
Re: marko rodin explaining his rodin coil
« Reply #8 on: March 28, 2010, 12:06:16 pm »
What should it suppose to do, this coil?
« Reply #9 on: March 28, 2010, 14:24:03 pm »
Hi I have all of rondins stuff  not had time to look at it much, lots of math
I tried to post but it went over the  charter ammount so if any one is interested let me kno, steve  I could put it all in a file and email it to you if you want.
aussepom
« Reply #10 on: March 28, 2010, 14:48:12 pm »
hi for those who beleive
 I stunmbled on this I will see itf it will fit.
God code
GREGG BRADEN'S
"GOD CODE"
An English Alphabet Code Analysis
By Gary Val Tenuta
©2005, Gary Val Tenuta
Brief Introduction:
Gregg Braden claims to have found a message encoded into the human DNA. The message reads "God eternal within the body" or, alternatively, "God within the body" (For a detailed account of his methodology see his book, The God Code). Suffice to say, for this brief abstract, his methodology included the use of gematria as related to the Hebrew alphabet/language. Now, using what may be thought of as English gematria, or what I call CryptoNumerology, we find support for Gregg's claim. The system used here is the simple English Alphabet Code (EAC) of A=1 through Z=26 (For a detailed explanation of what CryptoNumerology is and how/why it works see CryptoNumerology: How and Why It Works). Using this system, words and phrases are converted into numbers by calculating the sum of the letter values. For reasons too complex to explain here, the value of the number 9 has a long history of significance in sacred texts, sacred geometry, Pythagorian mathematics, and mythological lore. The single digit value of 9 is often "hidden" within larger numbers. For example, the well known "666" from the book of Revelation in the Bible reduces to 9 by the method known as "cross-adding". This simply means calculating the sum of the individual intigers in the number until only a single digit remains: 6+6+6=18, then 1+8=9.
Notice all the number values in the work shown below reduce to the single digit value of 9. This is important, especially in the case of this "God Code" analysis, because:
NINE IS THE KEY= 144 = THE SECRET KEY
DOUBLE HELIX CODE = 144 = JEHOVAH ETERNAL
The number 144 is itself an important sacred number. Esoterically, it is thought to be associated with the concept of "light". This is interesting as it is generally accepted that the Great Pyramid was originally covered with 144,000 sheets of highly polished limestone, thus causing the pyramid to gleam like a "light" in the bright sun and could be seen for many miles. The number 144,000 is also significant in the book of Revelations, not to mention it appears as one of the significant numbers in the ancient Mayan system of calendar reckoning. These are just a few examples to demonstrate the importance of the number 144,000 and the harmonic 144.
Lastly, to answer the objection that there are many words and phrases which can generate these same numbers and that many of those words and phrases will have nothing in common with each other, conceptually, I should introduce the notion of what I call "Case Relatedness". Simply this means that when using CryptoNumerology to explore any given subject, I focus only on words and phrases which are, in some recognizable way, associated with each other in terms of concept and/or meaning. These are case-related words and phrases. This reduces the probability of chance in terms of matching alphanumeric values. This idea is not without precedence as it was also used in the gematria of Hebrew and Greek tradition.
With that brief introduction, the following work demonstrates how Braden's claim of a message ("God eternal within the body"), encoded in the DNA, is supported by the English Alphabet Code of CryptoNumerology.
We begin with a stunning corroboration of Braden's discovery as we find the scientific name for DNA (Deoxybribose Nucleic Acid) associated with three key "case related" phrases which include the original Hebrew spelling of the name of God, YHVH (transliterated, Yahweh) and a number value that reduces to 9. This is followed immediately by another alphanumeric equation in which the phrase "Christ Consciousness" is included. (Note: The appearance of the word "Christ" in this context may not necessarily be a direct reference to the religious figure known as Jesus. The exact phrase is "Christ Consciousness", indicating a level or dimension of consciousness rather than a specific person.)
_____________________________________________
YHVH WITHIN THE BODY = 225 = DEOXYRIBOSE NUCLEIC ACID =
NINE IS AN ORGANIC NUMBER = YHVH CODE WITHIN THE DNA
DEOXYRIBOSE NUCLEIC ACID CODE = 252 = CHRIST CONSCIOUSNESS
Again, note that each of these alphanumeric values reduces to 9.
JEHOVAH ETERNAL WITHIN THE BODY = 306 = 9
Note: Jehovah, of course, is yet another variation on the name Yahweh from the Hebrew root YHVH. The letters YHVH, by the way, have an English Alphabet Code value of 63 which also reduces to 9. Furthermore, we find the value of the word GENETIC is 63 and the value of the phrase GENETIC CODE is 90.
GOD IS WITHIN THE BODY = 216
THE CODE WITHIN DNA = 162 = WITHIN THE BODY
YHVH CODE = 90 = DIVINE CODE
YHVH CODE WITHIN THE BODY = 252 = DIVINE CODE WITHIN THE BODY = CHRIST CONSCIOUSNESS = DEOXYRIBOSE NUCLEIC ACID CODE
YHVH WITHIN THE DNA = 198 = THE GOLDEN MEAN SPIRAL =
THE FEMALE NUMBER = THE RESURRECTION = THE NINE SACRED TONES =
THREE SIX NINE CYCLE
Note: The equations above introduce the concept of "tone" into the mix. Tones or sounds suggests "frequency" and "vibration". More of this follows.
THE THREE SIX NINE CYCLE IS THE KEY = 333 = THE SOURCE OF CREATIVE INTELLIGENCE = THE VIBRATIONAL FREQUENCY OF NINE
Also, from http://members.aol.com/MetPhys/100electronscale.html
we find the following information:
<< The E flat note at 639 Hz is close to the frequency of the kung note in the Chinese system of music. According to David Tame, "this foundation note was considered to be the earthly manifestation of divine will, and a sacred, eternal principle, upon which was based the proportional system (the weight, size and tone of all things) of the entire state." (69) If the kung was wrong, civilization would decline. Unfortunately, the ruler of each dynasty changed the value for the kung because they reasoned that if the previous dynasty had been right, it wouldn't have ended. The last Chinese dynasty put the kung at 601.5 Hz, a D. They were wrong.
The central role of the E flat note was pointed out by Barbara Hero in her collection of musings and sketches on the mystical aspects of music, Eyes + Ears = Ideas. She found that it was at the beginning, end, or other key locations in 18 different musical, mathematical or metaphysical patterns. She wrote, "It's the place at which we find the beginning of life, and the fastest musical pulse of the thirty second note... It becomes the boundary of the end of the time where space begins... it is at the limit of the macrocosmos."
To fully explain the significance of what Barbara Hero wrote above is beyond the scope of this newsletter. If you are intrigued, I would recommend that you get the book. It is available to read on-line but unfortunately the illustrations are illegible. Suffice it to say that the E flat note at 639 Hz corresponds to the kung note and to "Aum," the cosmic tone of Brahma, the creator. I am not saying that 639 Hz is the actual frequency of the tone of creation. It is the octave of that tone which the human voice can recite comfortably. >>
Note: Some researchers have suggested that sound can be used as a healing tool. With this in mind we find familiar numbers associated with these case-related phrases:
THE HEALING TONES = 162 = THE THREE TONES = HARMONIC SOURCE = GOD IS THOUGHT
ONE SIX TWO = 144
THE DNA HEALING CODE = 135
CIRCLE OF TONES = 144 = THE HUMAN TONE = SIX NUMBERS
SIXTH NUMBER = 153 = FLESH BLOOD AND BONE = TETRAGRAMATON = HARMONIC WORLD =
THE GOLDEN RATIO = THE KINGDOM OF GOD
YHVH = 63 = DIVINE
The following are phrases from John 1: 1-14 in the King James Bible:
"The Word was with God"
"The Word was God"
The Word was made Flesh"
We know, from previous work, that VOICE = 54 = TONE. The verse from the book of John suggests that God "spoke". This implies "voice" which suggests sound or tone. We also know, from previous work, that VOICE OF JEHOVAH = 144. These self referencing number/concept matches suggest a good reason to substitute "tone" for "word" in the Bible verse. When we do that, we find the alphanumeric value of this entire section of verse comes to 594 (an important number in its own right for reasons too extensive to go into here) and we also see the familiar code number, 216, within the structure:
THE TONE WAS WITH GOD = 216
THE TONE WAS GOD = 175
THE TONE WAS MADE FLESH = 203
216 + 175 + 203 = 594
FIVE NINE FOUR = 144 = SIX NUMBERS
What can the phrase, "SIX NUMBERS" possibly refer to? The following may provide an answer.
In the AlphaNumber Table that I devised a few years ago I converted the numbers 0 through 9 into what I call "AlphaNumbers". That is to say, I converted the numbers into words (i.e., ZERO through NINE) and calculated the alphanumeric values of each. I found that these AlphaNumbers could be divided into sets according to how many letters were in each AlphaNumber. The 3-letter set is ONE-TWO-SIX. The 4-letter set is FOUR-FIVE-NINE (Of course ZERO also has 4 letters but it is a special case and not included in the 4-letter set). Without going into detail regarding the entire AlphaNumber Table suffice to say, for the sake of this discussion, that the alphanumeric value of each of these two sets of AlphaNumbers (ONE-TWO-SIX and FOUR-FIVE-NINE) is 144. These are the only sets of AlphaNumbers with that value. Since 144 is a significant sacred number it suggests there may be something special about these two sets. Notice these two sets are comprised of three AlphaNumbers each, thus giving us "SIX NUMBERS".
Maybe the six mystery numbers are 1 2 6 4 5 9 in some sequence.
ONE TWO SIX FOUR FIVE NINE = 288 = 144x2
Now, admittedly the next phrase is not quite grammatically correct and yet could be construed as having a particular meaning in its apparent ungrammatical form. In any case, the value of the phrase is striking, given the current discussion:
ONE TWO SIX FOUR FIVE NINE ARE THE KEY NUMBER = 459
With the use of the word "are", one would expect to see the plural, "numbers". However, given the alphanumeric value that the phrase produces, perhaps the message is that these are to be considered as a single number rather than as separate numbers. The single number, comprised of six digits, would be 126459 or some sequence of those digits. I don't know. It's only a suggestion at this point. However, this is interesting:
1+2+6+4+5+9 = 27 = CODE
Let us continue now to see more of these case-related phrases and how they fall into line with Braden's apparent discovery of a message encoded in our DNA:
SIX IS THE CREATION TONE = 252 = CHRIST CONSCIOUSNESS = DEOXYRIBOSE NUCLEIC ACID CODE
FOUR FIVE NINE ARE THE HOLOGRAPHIC NUMBERS = 405
FOUR IS THE HOLOGRAPHIC NUMBER = 306 = JEHOVAH ETERNAL WITHIN THE BODY
FIVE IS THE HOLOGRAPHIC NUMBER = 288
NINE IS THE HOLOGRAPHIC NUMBER = 288
306 + 288 + 288 = 882 (reverse of 288)
And likewise:
ONE TWO SIX ARE THE HOLOGRAPHIC NUMBERS = 405
ONE IS THE HOLOGRAPHIC NUMBER = 280
TWO IS THE HOLOGRAPHIC NUMBER = 304
SIX IS THE HOLOGRAPHIC NUMBER = 298
280 + 304 + 298 = 882 (reverse of 288)
What does the notion of "holographic" have to do with DNA? In Michael Talbot's remarkable book, The Holographic Universe, he presents several arguments by reknown quantum physicists and neurobiologists postulating that the human brain operates on holographic principles. If this is true then surely the DNA by which the brain structure and function is determined must also contain the principles upon which a hologram works. We know that a hologram is an information storing system. Interestingly, our CryptoNumerology by way of the English Alphabet Code supports this notion:
DNA IS AN INFORMATION SYSTEM CREATED BY INTELLIGENCE = 495
FOUR NINE FIVE = 144
DNA IS A HOLOGRAPHIC SYSTEM = 261
TWO SIX ONE = 144
HOLOGRAPHIC UNIVERSE = 225 = DEOXYRIBOSE NUCLEIC ACID CODE = DOUBLE HELIX GEOMETRY
GEOMETRY OF THE DOUBLE HELIX = 279
GEOMETRY CODE OF THE DOUBLE HELIX = 306 =
THE SPIRAL CODE = 135 = THE DNA HEALING CODE
THE DNA HEALING CODE GEOMETRY = 243
THE SPIRAL = 108 = GEOMETRY
CODE TONE = 81
THE CODE TONE = 114 = FREQUENCY
THE THREE TONES = 162 = THE CODE WITHIN DNA
THE THREE TONES OF THE CODE = 243 = THE DNA HEALING CODE GEOMETRY
THE SIX NUMBERS OF THE THREE TONES = 360 (Suggesting complete circle? Cycle? Also suggesting the 6 frequency numbers of the ancient Solfeggio scale?)
1. UT ¬ 396 Hz ¬ Liberating Guilt and Fear
2. RE ¬ 417 Hz ¬ Undoing Situations and Facilitating Change
3. MI ¬ 528 Hz ¬ Transformation and Miracles (DNA Repair)
4. FA ¬ 639 Hz ¬ Connecting/Relationships
5. SOL ¬ 741 Hz ¬ Awakening Intuition
LA ¬ 852 Hz ¬ Returning to Spiritual Order
What are the Solfeggio frequencies?
According to one source (http://hometown.aol.com/codeufo/%3cblockquote%3e%0a%20%20%3cfont%20size%3d+1%3ehttp://www.lightwithin.com/SomaEnergetics/4Certification_Workshops_Schedule.htm%3C/FONT%3E%3C/BLOCKQUOTE%3E%0A):
"These original sound frequencies were apparently used in Ancient Gregorian Chants, such as the great hymn to St. John the Baptist, along with others that church authorities say were lost centuries ago. The chants and their special tones were believed to impart tremendous spiritual blessings when sung in harmony during religious masses. My thanks to Dr. Joseph Puleo for rediscovering these frequencies and returning them to humanity."
Having heard Dr. Leonard Horowitz speak about Dr. Puleo's work with these frequencies I knew that Puleo had recognized what seemed to be a significant element regarding the frequency numbers. That is, the numbers reduce, in sequence, to the single digit values of 9-3-6-9-3-6. I had found this same situation to be the case for the word, FREQUENCY, as shown here:
FREQUENCY = 114
114 x 1 = 114 = 6
114 x 2 = 228 = 3
114 x 3 = 342 = 9
114 x 4 = 456 = 6
114 x 5 = 570 = 3
114 x 6 = 684 = 9
114 x 7 = 798 = 6
114 x 8 = 912 = 3
114 x 9 =1026 = 9
The order of the single digit values is different (6-3-9 as opposed to 9-3-6) but perhaps the order of sequence is not as important as the triads themselves regardless of the sequence. In fact, when I realized they were triads I discovered the sequence yet again:
SIXTH TRIAD = 132 = 6
THIRD TRIAD = 111 = 3
NINTH TRIAD = 117 = 9
Now I didn't know what this might mean but I did notice that the 3rd, 6th, and 9th numbers in the list that resulted from the word FREQUENCY are the ones that reduce to 9. When we calculate the sum of those numbers (342+684+1026) we get 2052. That number was not familiar to me as it did not refer to anything else in my notes that I've archived over the years. Curiously, however, when that number, 2052, is divided by 3 the result is 684, the same as 114 x 6, the last number in the second triad in the list and/or the 6th number from the top of the list. So once again we find the idea of the "SIXTH NUMBER" showing up in this analysis. Futhermore, the sum of 132+111+117 is 360. This number suggests a complete circle in conventional arc degrees. It is also, curiously enough, the alphanumeric value of the following phrase:
THE TREE OF THE KNOWLEDGE OF GOOD AND EVIL = 360
Note, also, the number 117 (the value of the phrase, NINTH TRIAD) relates to Braden's "God Code" in the DNA especially if the purpose of the "God Code" is to communicate information:
DOUBLE HELIX = 117 = COMMUNICATE
Regarding the 6-3-9 sequence, we see how this repeats, 6-3-9 / 6-3-9 / 6-3-9.
This suggests a cycle which brings us back to some significant phrases introduced a few pages back:
And one more flag went up with this:
SIX THREE NINE = 150
150 x 1 = 150 = 6
150 x 2 = 300 = 3
150 x 3 = 450 = 9
150 x 4 = 600 = 6
150 x 5 = 750 = 3
150 x 6 = 900 = 9
150 x 7 = 1050 = 6
150 x 8 = 1200 = 3
150 x 9 = 1350 = 9
_________________________________________________ _________
As an aside, although still relevant, I've been told that in the King James Bible the center chapter is Psalm 117. Recall DOUBLE HELIX = 117 = COMMUNICATE. If the information is correct there are 594 chapters before Psalm 117 and 594 chapters after Psalm 117. I seem to recall that 1188 is a gematria number from the Hebrew system. I can't recall what meaning is attributed to it but it's the sum of 594 + 594. Another interesting thing is the reversal that takes place with the sum of 117 and 594:
594 + 117 = 711
Since the number 144 is considered such a significant sacred number, and has appeared many times in this analysis, it seemed like a good idea to include a list of the interrelated phrases that I've found so far which have an alphanumeric value of 144.
JEHOVAH ETERNAL
GOD IS SELF AWARE
THE GOD OF ISRAEL
VOICE OF JEHOVAH
I AM ALPHA AND I AM OMEGA
I AM THAT I AM NOT
SERPENT OF GOD
BODY OF CHRIST (Note: SPIRIT OF CHRIST=189. 189+144=333)
NOTHINGNESS
MULTIVERSE
MARK OF THE BEAST
THE DIVINE CYCLE
REVERSE SIX
CIRCLE OF SOUND
CIRCLE OF STONE
CIRCLE OF TONES
CIRCLE OF NOTES
THE PHI SCALE NODE
THE NINE CIRCLES
SPIN THE WHEEL
ONE TWO SIX
FOUR FIVE NINE
THE ALPHANUMBER
THE ILLUSION
THE COMPUTER
SQUARE OF FIVE
SQUARE OF NINE
DIVINE SQUARE
GEOMETRIC SHAPE
SIGN OF THE CROSS
NINE IS THE KEY
THE SECRET KEY
THE PHASE SHIFT
EARTH TEMPLATE
CROP TEMPLATE
Conclusion:
Some of these phrases remain a mystery to me as far as what they might actually mean. For example the phrase, SIX IS THE CREATION TONE, seems to not make sense on its face; yet, on an intuitive level it has the "feel" of something that might make sense if only we knew the precise context in which to place it. The same might be said of some of the numbers. Still, given the preponderance of these numbers (such as 144, 162, 459, 117, etc.) and all their respective permutations resulting from this matrix of case-related phrases, and their close (and often dead on) correspondences with Braden's "God Code", one certainly is tempted to believe a message is trying hard to come through the noise.
its a mistry to me
aussepom
« Reply #11 on: March 28, 2010, 17:22:37 pm »
ok in this pic i brought out another observation.. notice all the different color square angles..  what i find interesting is that if you look at each square one end of the square is the mirror of the other side of the same square.. then the corner number is a mirror in itself!! eample would be 747 mirrors itself..
i put a orange circle around the yin and yangs of the square.. and as you can also see there also is the dividing red line diagonaly across the center..
on rodins coil he claims that he has developed the perfect geometrical design for a coil that interacts with its surounding space magnetically and is able to create more magnetic energy then with a standard iron core transfomer..
rodins coil is pretty simple he winds it with bi filar winds and leaves a gap between bifilars to allow the flow and interation with aether channels of energy..
i think stans circuit has some resemblence to this .. i think instead of the aether flow being present in lets say the alternator its actualy occuring in the cell gap.??  im just trying to draw a broader pic of posibilities of resembling the 2 free energy devices..
« Reply #12 on: March 28, 2010, 18:27:01 pm »
What I have noticed it that where the wires cross in the coil at an angle there's a non-inductive point or cancellation.  I would not be surprised if a 5 pointed star winding had a similar or more profound effect.  I haven't tried it yet.  It's a lot like a moebius coil winding.  I've brought this up in other places; if energy is neither created nor destroyed, if waves cancel what happens?  It has to be a transformation.
Andy
« Reply #13 on: April 26, 2010, 16:07:43 pm »
well the way i see it from markos perspective that the rodin coil is wound so profoundly that there are no effects within the coil of resistance due to contradicting fields which exists within all common coils today.. its one of the main reasons they get hot...  he also says that there is no ELECTRON SPIN DEGRATION i find this to be the reason of signal distortion.
its interesting that we can consider rodins coil a bifilar design  since it does have two equal length wires just under different  geometrics when it comes to the wind style... his design doesnt require a steel core since his magnetic fields are not within the coil rather all around and outside.. his magnetic field is said to be much stronger then a standard core design coil.
this leaves me seeing rodins coil as one that can resonante at a higher variety of frequency without signal degration and loss of power in the form of heat
i would like to make one of these soon and experiment with it using  the electrical polarization setup... i would like to see whhat this coil will do set up as a VIC.. i would also like to see it place with the tube cell in the coils hole.. imagine if the rodin coil is a atom pulser the magnetic fields being generated in that coil with a high ring (vic) may show interesting results.. who knows
well if energy is is neither created or destroyed that must mean energy is considered a object correct?  shall we say density (photons are elementry particles).. can this density be consumed? when i say consumed i do not mean destroyed i mean taking on by the atoms and stored as potential energy of some sorts within or around the atom during ionization.. i would say it would show its effect of taken on energy (object) as expanding gasses right?  and even if thats not the case.. we can consider its still a object.. is it being stored or just being  used to accelerate under a resistive circuit?
« Reply #14 on: July 28, 2010, 17:08:04 pm »
came up with somthing interesting thought i would share...  in the tesla tech video i posted with marko rodins partner jamie.. he says they are winding them coils in another manner then showed on previous videos.. i took a old bike wheel and cut out the spokes. it had 36 spokes giving 10 degrees spacing.. i then looked up the angles of a 5 pointed star and plotted them on my rim..  i am curious of the 5 pointed star due to the facts that they have related it to satanic ritual.. i think that relation is for fearmonger to keep minds from think about the 5 pointed star in a good way..   so i looked up the angles and got,
there are two 5 pointed stars here represented in green and yellow..
now go ahead and apply some rodin math to these degrees and tell me what you get..
im not sure if this is his new method but it is sure interesting how all the angle add up to 9
(http://www.greatdreams.com/radio/oz/dblstar.gif)
now do it to the inner angles and tell me what you get.
(http://dudeman.net/siriusly/ac/geom/5star.gif)
« Last Edit: July 28, 2010, 21:22:32 pm by outlawstc »
« Reply #15 on: July 28, 2010, 23:11:13 pm »
Math is a nice thing. Whole of nature is full of it.
The question if energy is consumed or is tranformed in another material or energy form is one many asked.
One thing is for sure.....Everything we are or see is energy and all is connected on way or the other way....
Maybe the following question is a nice one for you Outlaw:
What does make that, as soon as you turn off power on a coil, the magnetic field turn into current?
Do the electrons a trick? What is pushing the magnetic particles into current in an inductor?
