Author Topic: marko rodin explaining his rodin coil  (Read 20036 times)
« on: February 24, 2010, 23:06:07 pm »
this is a 4hour and some odd minite video of morko explaining vortex energy and his coil design.. very different and new territory..
http://video.google.com/videoplay?docid=-7911972442098545165#
Re: marko rodin explaining his rodin coil
« Reply #1 on: February 25, 2010, 03:46:57 am »
This seems like there's lots of potential.
Its also not out of site to make.
Over at EnergeticForum they got some good Rodin info and Stubbs is doing pretty good stuff.
Guess there's a couple ways to make it but with a iron or ferrite core it seems it has more overall strength.
Might be worth looking into.
Thanks outlawstc
Thats a long video but an interesting subject.
« Reply #2 on: February 27, 2010, 08:25:27 am »
stan says that when you first introduce the pulsing of gaining resistive potentials to the plates they themselves will magnetically polarize north and south... im guessing the positive plate due to it pulling electrons will have opposite electron spin AND orbital oscillating direction then the negative plate. imagine how the opposite spins can help to add energy in the form of velocity to orbital electrons of water..
ok another quick observation.   marko rodin when putting a non magnitized drill bit into the center of his coil turned it into a monopole.. it showed a north polarity on one end and the other had no pole at all!! i find this relative to stans idea of unipolar (1 polarity pulsing.. )
so all in all i think you can say that markos geometrical electrical design creates the perfect aperture for pulsing atoms and is a aether pump.
ok you math whizzes i am finding more crazy relations between stans alternator to the rodin design.  he explains that nature can be represented by numbers..
the rodn coil has bifilar coils as does the alternator.. there is gaps between bifilars of the rodin coil and they are considered a aetheric path on the coil..
with the the alternator i think may be related to the secondarys involvment in the circuit?
he explains the bifilars are represented with the sequence 124875flowing one way in a bifilar while the other is exact opposite 578421 in the other
pretend these numbers are wires horizontal and rep phase potential
1248751248751248751248751
1578421578421578421578241
6693396693396693396693396
5124875124875124875124875
2157842157842157842157824
9669339669339669339669339
now imagine these numbers as 2 sets of bifilars which are the 124875 an 578421 and the other 9339669 is the aetheric fluxuation around the rodin coil... also see this cube of numbers like a checker board of opposite polarities ex .+1-2+4-8+7-5 and +5-7+8-4+2-1
 these numbers represent a doubling circuit i suppose 1 doubled is 2. 2 doubled is 4. 4 doubles is 8... 8 doubled is 16.....1+6= 7 and thats where the number 7 comes from  then 7 doubled is 7+7= 14 which is 1+4 and thats the repesentation of 5
the number 9 some how relates to the axis of the atom...
to picture the number nine as a part of a yin yang its the curving line in the middle while the white and black dots are 3 and 6 in relation to the big picture.. im still trying to grasp it all and see how much it relates...  all these numbers can be laid out in a clock like pattern
the alternator has 12 loops per phase 1+2= 3
it has 36 cavitys in all 3+6=9
it has bifilars placed parallel to each other around the core each spaced 30 degrees from center 3+0=3
the rotary vic alternator has stacked layers in a reps of bilf, sec, bilf, sec, bilf, sec.
this may have no relation... he explains his toroid to operate under perfect electrical sequence that doesnt deal with resistance due to out of phase relationship with  other wires or somthin like that.
« Reply #3 on: February 27, 2010, 14:56:54 pm »
I sort of see where you are trying to go but I don't think it will happen the same way as the Rodin coil.
369 on the alternator are used within the coils so there's no aetherteric force unless you find another winding method and relate it to the alternator somehow.
That would be very interesting. Maybe by taking winding 3 out for a start, seems relateable to Rodins coil paired 1&2 bifilars.
You got 36 wells and 6 fingers of each positive and negative on a rotor. 6+6=12 = 3
Its like 6 becomes your ying and yang not 9. So what about a 18 pole 9 north 9 south rotor, does it exist?
If you gave it some more thought maybe a new mathematical rewind.
Because like you say it has some relation to numbers that match, and quit possibly in another way.
Makes me wonder about taking out winding 3 and whether that empty space can have aetherteric forces eminate from it?
« Reply #4 on: February 27, 2010, 17:55:16 pm »
yea taking out 3 may allow for some sort of aetheric flow maybe..
what im seeing is the rodin coil has a figure 8 wind with a flow like this >8< which is like the photo on bubs thread.. energy aperture of the atom.. all the coils around the stator are flowing like that in a sense ... i think the rotor is pumping the field and the coil contributes once energized?
my rotor has 6 north and 6 south.. 6+6=12 which is another 3 so there is the number 6 involves in the rotor and 3 .... 9 in the stator of 36 cavities.. 3 wires in each phase is 9 wires total having 18 ends which is 9.
now this is just coincidence but i wound my coils 30 loops each which is 3 and since theres loops of 30 and there is 12 i have 360 winds per wire which is 9..  a total of 3240 for all winds which is 9..  if there are any harmonics in relation to wind count i may of lucked it..
i finished installing the wire on my stator yesterday and it sure looks perty.
« Reply #5 on: February 27, 2010, 18:19:10 pm »
coral castles code to the universe is
7129
6105195
7+1+2+9= 19  so 1+9=10 and 1+0 is 1
6+1+0+5+1+9+5= 27  and 2+7=9
1/9 ???
somebody else who has found revelence in this code broke it down into sections like this
7  129
6  105  195
this will show
7 3
6  6  6
now thats freaky
7+3= 1
6+6+6= 18 which is 9 and you end up with 1/9 again.
« Reply #6 on: February 27, 2010, 18:49:53 pm »
Funny thing about the 30 winds per loop.
That 27 winds per loop = 324 turns = 9
2+7=9
9+9=18=9
So 27 also is a good number.
All combinations of winds with the number 3 seem to add up to 9.
Here's something else that may have consideration thats been on my mind for a little while.
What is you wound coils for each phase as done with bifilars no change there but......
Okay you got 30 winds on coil one, 27 or so on coil 2, 24 or so on coil 3. A  system like that.
The voltage has created a step, sort of a forced step.
Sounds interesting to me. Thats another off-shoot.
« Last Edit: February 28, 2010, 19:01:06 pm by komtek »
« Reply #7 on: March 27, 2010, 20:10:05 pm »
i wanted to share this visualization i drew up yesterday..  ever since i stumbled across rodins work i have been in search of a deeper understanding...   rodin says that 369 pattern is spirits (aether)  paths while electric travels in 124875 pattern in opposite direction..
he explains that 9 is center and represents the dividing line in the yin yang.. he says 3 and 6 are the good and evil dots in the yin yang.. 3 would be the white dot and 6 would be the black dot..  this to me means that 9 is a mirror.. 3 is opposite of 6
(http://www.vitamincity.com/pix%20rodin/Symbol_Of_Enlightenment_Aet.gif)
here is a perfect example of how 9 has somthing to do with center.. if you were to observe the multiples of 9  up to 10 you can see it holds some significance to number centers and a balance..
09,18,27,36,45,54,63,72,81,90
in this example center is between 45 and 54..             09,18,27,36,45(center)54,63,72,81,90
the center is a mirror   09 is a mirror of 90, 18 is of 81, 27 is 72, 36 is 63 and 45 is 54.
so i decided to see what it looks like to 100
                    1         2          3        4         5        6       7        8         9         10
1-10           [09       18        27       36       45 {}  54       63       72       81      90]
11-20         {99}     [108     117     126     135   {144}    153     162     171      180]
21-30         [189 {} 198]   [207     216     225     234 {} 243     252     261      270]
31-40         [279    {288}   297]    [306    315     324    {333}   342     351      360]
41-50         [369     378 {} 387     396]   [405     414     423 {} 432     441      450]
51-60         [459     468    {477}   486     495]   [504     513    {522}   531      540]
61-70         [549     558     567 {} 576     585     594]    [603    612 {} 621      630]
71-80         [639     648     657    {666}   675     684      693]   [ 702   {711}    720]
81-90         [729     738     747     756 {} 765     774      783     792]   [801 {} 810]
91-100       [819     828     837     846     {855}  864      873      882    891]    [900]
what i did in the above numbers is symbolized the groups of mirroring numbers.. the outside of these sets are symbolized by the [ and ]  while the center of each set is represented by { and }
what i beleive this number chart symbolizes is the yin yang in numbers..  it a perfect square of numbering being 10x 10..    now your probably wounder why i relate this to yin and yang in numbers..
if you look at the groups of mirrored numbers they make a perfect diagonal cut in the numbers fro 09 to 900 dividing the 100 squares into 2 triangles. the diagonal cut is like the center dividing line of the yin yang..  now if you look even closer you will notice that one triangle center number is 666 while the other side is 333...
i find it neat that these numbers show it and im also curious to what other clues it may hold to the sequencing current and electric... since stan does claim to pulse water in a sequential mode..
