Author Topic: Circuit Simulator  (Read 9577 times)
Circuit Simulator
« on: December 29, 2009, 08:59:22 am »
I've been playing with it for hours, really interesting.
Here is my latest, my basic idea is that the bifilar chokes are a 1:1 transformer connected in a sideways orientation... so far I can't figure out how to get it to resonate with DC
I've gotten this circuit to resonate up over 650 KV, just flick the switch in the center a few times and the voltage jumps up, but I don't really understand what it's doing. I've been trying lots of different things, and will continue to experiment!
$ 1 5.0E-6 30.13683688681966 48 5.0 50
R 352 240 320 240 0 1 20.545 5.0 0.0 0.0 0.5
R 352 304 320 304 0 1 20.545 5.0 0.0 3.141592653589793 0.5
d 352 240 400 240 1 0.805904783
d 352 304 400 304 1 0.805904783
w 400 304 400 240 0
d 400 240 448 240 1 0.805904783
T 544 288 608 288 0 1.0 1.0 -0.09033476664486628 0.0903347666358475
w 544 240 544 288 0
w 608 288 608 240 0
w 608 320 688 240 0
c 576 144 544 144 0 6.8483E-7 -0.09020711715857033
w 608 192 608 144 0
w 544 192 544 144 0
w 544 144 544 96 0
w 608 144 608 96 0
r 544 96 576 96 0 1.0
r 576 96 608 96 0 1.0
c 576 144 608 144 0 6.8483E-7 0.09020711715857033
d 544 240 544 192 1 0.805904783
w 576 144 576 96 0
g 576 208 576 240 0
s 576 144 576 208 0 1 false
d 608 192 608 240 1 0.805904783
d 352 448 384 416 1 0.805904783
d 384 416 416 448 1 0.805904783
d 352 448 384 480 1 0.805904783
d 384 480 416 448 1 0.805904783
w 384 416 304 416 0
w 384 480 304 480 0
v 304 416 304 480 0 1 41.09 5.0 0.0 0.0 0.5
w 352 448 352 400 0
g 352 400 352 384 0
g 688 240 704 240 0
S 496 384 464 384 0 0 false 0 false 0
w 448 240 464 368 0
w 416 448 464 400 0
w 544 320 496 384 0
o 7 64 0 291 20480.0 1.6 0 -1
o 8 64 0 291 20480.0 1.6 1 -1
o 35 64 0 35 5.0 1.6 2 -1
o 34 64 0 35 5.0 9.765625E-5 3 -1
Re: Circuit Simulator
« Reply #1 on: December 29, 2009, 10:39:09 am »
Yes, Donald.
Its so much fun!
Its such a nice way of testing, without soldering..
« Reply #2 on: December 29, 2009, 20:38:19 pm »
Ok, here is an almost working VIC!
There are two things left to figure out with this circuit, and then it will be working as best as I currently understand.
1. Add in realistic resistances.
2. Calculate proper resonant frequency with resistance added.
I played around with this circuit for about 1.5 hours, or maybe more, trying lots of resistances, and the I realized that as you change resistance, it changes your resonant frequency! So if you solve these two things you'll see all the waveform clues stan was showing and talking about.
It has step charging, it has resonance, it has equal and opposite voltage, it has additive magnetic fields for the chokes, it has gating, it has continued resonant action during power-off stage (Stan says he was able to produce 19 times more gas on the power-off stage once excited into resonance)
To see all the above effects with this circuit you need to play with the resistance, but then resonant changes, so you can see all of these, but not all at once, until you match the resistance with the resonance, then you should.
Two more things with this circuit
3. The chokes are modeled as a 1:1 transformer sideways, and they do not increase the voltage with inductive reactance in this simulator, as far as I can tell.
4. The cell is modeled as a capacitor for each plate, so you can distinguish the voltage, with a resistor in parallel for the leakage. The resonant effect can be seen on the wire in between the resistor and capacitor.
Finally, the problem Dynodon and Webmug have with their real circuit.
5. The resonance is an AC swing! even though the voltage on the plates is always unipolar, the resonant voltage is AC... I don't know how to fix it in the simulator, but it's at least comforting to know this happens in the real circuit too...
Maybe with more playing around we can fix this.
w 368 272 304 272 0
w 368 336 304 336 0
v 304 272 304 336 0 1 60.0 12.0 0.0 0.0 0.5
T 544 272 592 304 0 1.0 1.0 6.994812438210207E-5 6.994813430183378E-5
w 400 304 400 272 0
w 336 304 336 352 0
g 336 352 336 368 0
w 528 416 528 384 0
w 592 416 592 384 0
w 528 384 528 352 0
w 528 352 544 352 0
w 592 352 592 384 0
d 368 336 400 304 1 0.805904783
d 368 272 400 304 1 0.805904783
d 336 304 368 336 1 0.805904783
d 336 304 368 272 1 0.805904783
g 688 304 704 304 0
w 688 304 592 304 0
w 640 320 592 272 0
c 528 384 560 384 0 6.8483E-7 0.0010349737713113427
c 592 384 560 384 0 6.8483E-7 9.650251595303416E-4
T 544 208 592 224 0 4.0 10.0 2.6645352591003757E-15 6.994812448624099E-5
d 592 240 544 272 1 0.805904783
g 592 208 624 208 0
R 352 176 320 176 0 2 20.0 5.0 0.0 0.0 0.5
w 464 272 544 240 0
t 480 176 480 208 0 1 0.0015140837095231063 -5.0 100.0
w 352 176 480 176 0
w 496 208 544 208 0
g 464 208 432 208 0
r 528 416 592 416 0 1.0
r 400 272 464 272 0 1.0
r 544 352 544 304 0 1.0
r 592 352 640 320 0 1.0
o 31 64 0 34 4.676805239458889 2.993155353253689 0 -1
o 19 64 0 34 0.29230032746618057 0.023384026197294447 1 -1
o 20 64 0 290 0.29230032746618057 0.023384026197294447 2 -1
o 7 64 0 290 327680.0 0.2 3 -1
(http://img.photobucket.com/albums/v81/bigbuba/Picture35-1.png)
« Reply #3 on: January 02, 2010, 07:55:05 am »
Just some comments on the VIC in general, after trying to model it in the simulator...
The chokes are a 1:1 transformer, positive voltage of any waveform and magnitude is sent through the positive choke and creates a 1:1 mirror version of this in the negative choke.
The negative choke is grounded, so it has nothing to do with the secondary, even when it is connected to to the secondary without a ground, it still produces the same waveform because the secondary goes from zero to positive, and the negative choke goes from zero to negative.
The secondary can be used to create any voltage setup you want, this is then sent into the positive choke, so long as the chokes are 1:1 you will get this mirrored on the negative.
The reason the magnetic fields of all the coils are aiding is simply because that's how you create a negative voltage. To illustrate this point, think of a center tapped transformer that is grounded in the middle, all the coils are wound in the same direction, magnetic fields aiding, but on the bottom side of the transformer you pull out a negative voltage equal and opposite to the top side of the transformer.
This is why the VIC still works without a center tapped secondary... you might think, and I did for a while, that it doesn't make sense to get an equal and opposite voltage out of each end when the secondary+positive choke is two coils above ground when you only have the single negative choke below ground... and it's because the secondary is irrelevant to the chokes 1:1 bifilar action.
Of course in the perfected design the secondary is resonating with the chokes, but I wont get into that now, I just wanted to point out how the chokes work in this manner.
The chokes also have other important characteristics and functions that i'll play with more later, such as distributed inductance and capacitance, inductive reactance, frequency doubling with blocking diode and collapsing magnetic fields... lots of fun.
« Reply #4 on: January 02, 2010, 08:59:10 am »
w 128 128 64 128 0
v 64 128 64 192 0 2 41.09 500.0 0.0 0.0 0.5
l 272 144 336 144 0 1.0 2.8295892323003278
r 336 144 400 144 0 10.0
w 224 144 128 128 0
c 272 176 336 176 0 1.4999999999999999E-5 471.58193274149505
w 336 176 336 144 0
w 272 176 272 144 0
d 224 144 272 144 1 0.805904783
g 64 192 64 208 0
g 400 144 400 208 0
o 3 64 0 42 1280.0 51.2 0 -1
Single resonant charging choke with blocking diode, resistor for wfc, shows frequency doubling and voltage doubling with spike.
Will try the VIC Matrix Circuit next...
« Reply #5 on: January 02, 2010, 19:51:38 pm »
Well, that's the most difficult part of the equation!
I'm still learning things about transformers.
As we know, all inductors have capacitance and all capacitors have inductance at specified frequency. We do want resonance to occur in this circuit, Yes? So why do we see a LCR circuit as different parts?
Did Stan designed his VIC transformer inductor to have "parasitic parallel capacitance" or "distributed self-capacitance" which also resonates with the choke "parasitic parallel capacitance"? Then you can see the LCR circuit without a Capacitor symbol in it. Don't see one in Stans circuit, but he talked about resonance, right.
I was testing a little transformer.
Prim. 1,8Ohm 3,25mH - Sec. 16Ohm 41,07mH. Used in an old PHILIPS TV.
Pulsing (DC 0-12Vpp 50%du)
When hitting resonance at about 150kHz it's generating a beautiful sine-wave 210Vpp AC signal. So the transformer acts like a LCR circuit.
If you put a DIODE at the AC output, you get different frequency (Unipolar Pulse) signal, then feeding into a choke... also hits resonance on that. To only thing the transformer must do is step-up the voltage from 12 or 24V DC to more, we want that, because it's creating huge EMF in the choke. The WFC cell acts as variable resistor (dielectrics), when little current is passing it increases resistance to a certain value the cell has...(electrolysis part) it steps-up voltage? When this value is reached you could gate this circuit (restrict more current).
The main problem/solution could be the "parasitic parallel capacitance" value of a inductor.
Why did Stan used cavities? Did he match capacitance (lower frequency)? PLL could be used for keeping it in resonance too.
Correct me, if I'm thinking wrong here.
Question @Dynodon:
Dynodon, have you seen capacitors at Stans place, connected at/in some circuit (alternator/VIC)?
Think about a FBT resonating at 15kHz AC, that connected to a diode and choke, resonating on "parasitic parallel capacitance" for optimal amp restriction, diode has no influence in this circuit.
Remember what's happening when you put a diode in a LCR circuit, it doesn't resonate!!!
br,
webmug
« Reply #6 on: January 02, 2010, 20:18:56 pm »
I still have lots more to play with and learn, but so far I have seen pretty much all the waveform and effects that Stan has talked about while trying to simulate his circuits, which is great news. I want to figure out how these different effects relate in the right context so that I can come up with the correct configuration. I'll have to re-read the patents and tech brief and try simulations of the stuff exactly as I read it so that I am not mixing different stuff.
« Reply #7 on: January 03, 2010, 01:18:52 am »
webmug,no caps in anything I saw there.Just the coils's he always talks about.
And yes you can get a lcr circuit to resonate with the blocking diode.I've been doing that for months now.But it still creates a negative component when viewed with a scope.
Don
