sorry to not post sooner. That is not a cup of gasoline. Hydrogen is lighter than air, Meyer had to "choke" the motor to keep the hydrogen from escaping. Once the vacuum of the motor was in effect the "choke" could be removed.
CrazyEwok, yes, if you use a regulator, it will output constant voltage, however this design is non-regulated, and using a constant speed motor with constant rpm, and a variac to control input to control output
I believe it,s a 3x5 file card which is being used to hold open the butterfly valve on the carburator. I use to do this all the time when my duster was flooded. You will see Stan put it in his pocket, a little hard to do with a cup
