Author Topic: Injector Dissasembly Pics  (Read 4471 times)
« on: December 26, 2007, 14:26:50 pm »
well pretty simple now that i used my Dremel to cuter open, it was well worth the wast!!! the picture says it all!!!
the magnetic coil is not wired to the barrel, so if i was to put this injector back together it would work if i hadn't destroyed it LOL.
now, you see the shinny spot on the casing? there are 2 of these, they're Electro Magnets.
in the end of the Factory injector, you would have seen 4 holes, about the size of half of a small sewing needle.
get rid of these 4 holes! im working on how.
you can see the ball point is the side that points to the motor, it does NOT have a hole in the end of hit, gas flows from the sides when the ball is pushed back by the electro magnet, this injector can pull .90 amps when hooked to a car battery. i would assume to use .50 amps.
the end hole i have showed with the 4 holes in where the gas comes out should have been drilled to one big hole.
now that i know and am sure how this works, i will take a new injector and drill me a bigger hole in it, with fear of lodging or sticking the injector.
« Last Edit: January 26, 2008, 13:00:44 pm by hydrocars »
Re: Injector Dissasembly Pics
« Reply #1 on: January 26, 2008, 13:02:08 pm »
i think you shouldn't drill the injector out, still not sure. things has changed now that water mist has came to play.
« Reply #2 on: February 11, 2008, 18:29:55 pm »
What's this injector out of?
« Reply #3 on: February 11, 2008, 18:41:36 pm »
1996 dodge neon
« Reply #4 on: February 11, 2008, 19:22:05 pm »
And that injector can flow gases?
« Reply #5 on: February 11, 2008, 20:16:17 pm »
it normally squirts gas out like a water pistil in 4 streams, it works good for a valve also, when the fluid starts to run out it will start to mist.
« Reply #6 on: August 11, 2008, 16:46:15 pm »
thats not gonna work  , stan talks about the injector in the patents
