Author Topic: Start here your topics on the water injector & ambient airgasprocessor system  (Read 45310 times)
Yes, don't work because you have the high resistance produce from distilled water. You need an ELECTRON EMITTER inside WFC cell.
Seem that you don't read my words.. dielectric absorption and electron avalanche.. you need to start from here.. You have to understand how work. On internet are presents great examples.. need that you open your mind.. forget Meyer papers for an second. Your mind must be think independently from these papers.
"The force of the free electrons is then enhanced by dielectrophoresis and electrophoresis acting in a nonuniform electric field (positive field) , resulting in the electrons being forced at a high velocity into a small volume surrounding the 'emitter device'. Such a device or configuration can be set up anywhere, on any scale - even inside a liquid providing the liquid is a dielectric."
Do you use a spark gap as electron transmitter,Tut?
NO! Any discharge inside. You need to create electrons flow inside. Need that you study dielectric absorption if you want really found the way. I repeat me .. You need and ELECTRON EMITTER INSIDE!
A kind of coating?
If you coating your wfc cell internally to outer tube and externally to inner tube  you create an simple DBD reactor.. but not an electron emitter.
Attached some types of DBD (Dielectric Barrier Discharge) Reactors
Fabio,
Inside your circuit I don't see any step-up transformer? How many voltage you produce? Inner electrode must be converted into electron emitter and outer tube must have positive field.   But you need high voltage for process dielectric water not low voltage. Free electrons, generated from electron emitter, must have high speed, they must impacts on  molecules  to knock of more electrons. HV Positive field on outer tube increase electrons speed. Now is more clear or you want that I sent you complete plans including UV reactor for micronic gas production? ;D
