Author Topic: Start here your topics on the water injector & ambient airgasprocessor system  (Read 45260 times)
Well, i think you are right cause you are coincidentally using same words as meyer to describe your results, like when you say water fuel gas.
I hope you can tell us more about the wave lengths involved and about the water state for the reaction.
You talk about brown gas, this confused me a lot if you are inputing the photon energy and reacting gases in a region with the electric field applied or if you are electrolyzing the water and than reacting the gas with the nitrogen with just photon...
However my best guess is that you are making all this inside an electric field and probably to maximize the surface contact the water is a fine mist of droplets or vapor.
Seems to me that you say "when molecules of water are extremely reactive as brown gas"
seems that you mean only changing the configuration of the water molecule, but not actually dissociating it is that correct?
How can you charge the water this way?
Is magnetic field required?
Thanks
BEst Regards
Fabio
HI Fabio,
One diagram is better then some words!
Now you understand?
Diagram posted in only for understand how principle work, you need to add some stage for filter KOH (if you use that), flashback arrestor, mixing chambre,etc..
I advise you about brown gas, first of all need to filter gas from electrolyte and water vapour because you can create poison gas very dangerous for life. Second if you use brown gas as additive for your engine you destroy your engine, the time of destruction depend only from the quantity of brown gas that you sent inside.. more brown gas and you destroy your engine fasctly. I have been tested that some time ago on special engine.. main problem is the oil mixed with water that creates an product similar to soap and accelerates the formation of rust on bearings and gears. All brown gas cells actually in commerce are very dangerous for your engine and your wallet. Micronic gas is the only solution. Regards Alessandro
« Last Edit: October 13, 2011, 22:19:09 pm by tutanka »
From that movie you can understand clearly what is really brown gas.. the extra electrons releasing when brown gas burn can vaporize metals, can melt different materials o metals togheter but brown gas return every water. See video at time 7:12. Imagine the effect of water inside your engine ..
http://www.youtube.com/watch?v=5B-YHLtG2hI
Nice Diagram. Thanks.
What is a water energizer?
So you are saying that you create HHO by common means than you amplify the thermal explosive energy adding the nitrogen to the mixture slowing down the burning speed and transforming the high btu in lower but with longer time?
Why you believe its HHO and not H2 and O2?
I thought you were interacting the nitrogen directly with water...
Water energizer add energy to water trough uv irradiation.. see image attached
Probably I haven't explain better..   brown gas is water at gas state, that is mixed with nitrogen molecular extracted from nitrogen membrane and sended inside first UV reactor, here water gas (not liquid or vapour), extremely reactive, absorb UV energy and released that ionizing the nitrogen. Is an strange reaction but nitrogen in presence of water gas ionize very faster when is UV irradiated. When mixture ionized of HHO and nitrogen pass inside second UV reactor water gas dissociate at 95% forming ammonia and nitrous oxide thanks to extra electrons released from water gas. Using only nitrogen (and not air)you form new stechiometric fuel (40% NH3, 60%N2O)  burnable with little energy discharge (0,07mJ) and powerful three times of gasoline.
 I hope that now you have understand..
« Last Edit: October 13, 2011, 23:22:23 pm by tutanka »
Very well my friend. I think now its clear to me... why you need two reactors?
Is these achievable using uv lamps? Or leds? x-rays? microwaves?
Is your production of HHO already over unity?
How much power output increase we are talking about here? I mean relating the burn of pure H2 and your micronic fuel? What exactly do you mean by 3 times that of gasoline? what is the comparative parameter?
would be possible to use pure hydrogen than to create this micronic fuel? Or it needs the complete reaction?
Cant you use the exhaust as source of nitrogen?
Thanks again
HI Fabio,
Now you understand?
Thanks for the drawing.
It made it more clear!
And of course, Fabio is asking all the questions that i also had...... ;)
Thanks again, Tutanka.
