Then you lose power.
http://www.youtube.com/watch?v=G-gVjnMHrSQ
True and exactly what i want it to do....
AHA!!
I think I see your plan Steve.
If you have a HHO supply under pressure; heating it (with waste heat) will increase the pressure/volume.
If you have enough pressure/volume the piston will be driven down on the intakestroke by said pressure!
This will give you an extra small power stroke!
It will also overfill the cylinder, like a turbo, compensating for volumetric efficiency losses on the original power stroke and negating all my previous arguements.
Heating the H2 will also change more of it into Monatomic H.
This gives a further increase in volume and increases the energy given off by igniting it.
Very Clever!
Or is it me being very clever!??
The fact that H has a higher octane rating (does not pre-ignite at higher compression ratios or in hotter conbustion chambers) means that ther should be no issues with knock.
You may have to beaf of your cooling though.
There is no way, at this point, of producing enough HHO onboard, but there is no reason why one could not set up a wind, solar and waste/p**p powered cell at home.
http://www.green-trust.org/wordpress/There are cells out there that produce HHO and pressurise it at the same time; easily found by Googling.
The tech to fill gass bottles is commercially available.
