Author Topic: Pulsed signal 60% more effective then strait DC  (Read 28142 times)
Re: Pulsed signal 60% more effective then strait DC
« Reply #56 on: December 30, 2013, 13:02:23 pm »
Steve said he used true rms meters and the result was the same
  • let the voltage do the work
« Reply #57 on: December 31, 2013, 00:01:35 am »
so there's more power out than in?
« Reply #58 on: December 31, 2013, 00:39:12 am »
I didn't build the setup yet.Hidro or Steve can answer that.
« Reply #59 on: December 31, 2013, 09:41:55 am »
did you watch the video,s?
« Reply #60 on: December 31, 2013, 14:50:35 pm »
try it....
« Reply #61 on: December 31, 2013, 15:13:33 pm »
ok I get it now , coil characteristics?
« Reply #62 on: December 31, 2013, 19:14:42 pm »
Some with a ferriet core and bifilar winding works.
I used two different types and both worked.
1: single layer bif 1mm wire, 100 windings on 1cm diam core.
2: 0,5mm wire bif on half moon core of old tv tube.
I dont have the specs from PT, but he used higher volts, big tube, 20cm diam toroid core..
With my tests on the joulethief i found out that twisted wire bifilar works great too.
« Reply #63 on: January 06, 2014, 21:04:43 pm »
I made the test today of the bifiliar setup.100t ,1mm wire  diam.and the choke made it worst,it acted like a resistor restricting half of the amps but also half of the voltage.power consumption was the same before the choke and after(0.25A).maybe i need to add some koh to make it draw more curent.
