Author Topic: Consumed power calculations  (Read 2931 times)
« on: September 09, 2009, 23:35:52 pm »
Hi all,
Question:
If you use a squarewave 50/50 for your setup, should we use voltage devided by 2 to get a good power reading?
V/2 x amps = used power
You all agree on this?
Re: Consumed power calculations
« Reply #1 on: September 10, 2009, 00:31:37 am »
yes that is correct , yes for power also . Unless there is some reactive elements . DC pulsed is harder to calculate .
My 50/50 12.04 volts cmos squares waves measure 6.02 volts
Stevie , I believe your chip is damaged , or your probe is showing that .
« Reply #2 on: December 26, 2009, 11:19:39 am »
An Ammeter should measure the amps witch is passing, there are ac and dc ammeters if you use dc ammeter it will measure only the amps that go in one direction so will give you the right amperage, is not important the duty cycle.
