Author Topic: Stan said: electrons are consumed...but are they?  (Read 9720 times)
Re: Stan said: electrons are consumed...but are they?
« Reply #8 on: January 17, 2013, 09:59:06 am »
The eec is a device that Stan used in the gas part.
He ionized it and then tried to catch electrons to prevent recombination of atoms, from my current point of view....
  • let the voltage do the work
« Reply #9 on: January 17, 2013, 12:29:30 pm »
I have come to some conculsions:  "an electric field removes ionized electrons reducing the rate of electron hole recombination , what you must do is control the electric field and maintain to regular levels , you can also ionize electrons using light quanta (laser field or light field) depending what electron band you want to excitate. if I was ionizing I wouldnt want any ozon forming ... earth receivers electrons very easily. it has a positive net charge.
About meyer you can do a lot with some alpha radiation alone , the electric field is maybe just there to keep atoms from recombining to electronically stable forms.. electrolysis produce some alpha radiation depending on the setup. you actually want to short-circuit water and control electron recombination to prevent water reformation you have like .5 seconds before that happens."
« Last Edit: January 17, 2013, 13:09:53 pm by geon »
« Reply #10 on: January 17, 2013, 16:43:35 pm »
Yes of course, I'm sorry I wasn't clear. Here is what I've been working on. I am working with gas
http://www.youtube.com/watch?v=gftvXx1hRME&list=UUDk1TaaIv-N3IKaNZh5T1GQ&index=2
http://www.youtube.com/watch?v=Tis4CBKOJ8s&list=UUDk1TaaIv-N3IKaNZh5T1GQ&index=4
http://www.youtube.com/watch?v=a7TmYb423YU&list=UUDk1TaaIv-N3IKaNZh5T1GQ&index=5
http://www.youtube.com/watch?v=5eoyoZwwsLQ&list=UUDk1TaaIv-N3IKaNZh5T1GQ&index=9
« Reply #11 on: January 17, 2013, 21:48:04 pm »
I have to admit, this is sort of bothering me also.  He doesn't show a true path for the electrons to go to once liberated from the water.  The circuit is left incomplete.  The only thing I can think of to complete the circuit is a center tap on the secondary OR that it dissipates as radiant energy, like a Tesla coil.
TS
