Author Topic: Urine turned into hydrogen fuel  (Read 5293 times)
« on: August 25, 2009, 21:32:24 pm »
Re: Urine turned into hydrogen fuel
« Reply #1 on: August 25, 2009, 23:05:16 pm »
Still uses KOH and amps, only interesting thing is that is requires 0.37 volts, which may make it more electrically efficient than distilled water, but it says the CO2 reacts with the KOH, which means your KOH will soon be used up, which would make a constant supply of KOH needed... it's all dead end.
« Reply #2 on: August 26, 2009, 03:21:41 am »
Yep ... You can only pee so much lol .
Just like you can only collect so much free restaurant grease .
You are 100% stuck untill you understand super-physics . Theres alot of good combinations techs say to save $ , potentially almost free ?, for the more humble type lol  ;) .
« Reply #3 on: August 26, 2009, 07:08:09 am »
« Reply #4 on: August 26, 2009, 10:21:31 am »
Hmmmm,
Smelly business.... :D
« Reply #5 on: September 29, 2009, 12:01:29 pm »
Wouter tested it here:
http://waterfuelforall.co.za/waterfuel-booster-frame.htm
Said it stank him scared!  :D
« Reply #6 on: September 29, 2009, 14:46:06 pm »
« Reply #7 on: September 02, 2016, 14:23:24 pm »
CH4N2O (urea)
N2O (Nitrous oxide)
Would it be possible to separate the Nitrous oxide from the rest and harness the power of this in the cars engine?
Maybe using a certain frequency or using an additive chemical?
