Author Topic: 16 plates cell project by Kumaran  (Read 23588 times)
Re: 16 plates cell project by Kumaran
« Reply #8 on: December 18, 2007, 01:49:22 am »
since the cats outta the bag, yeah its not PWM, this is totally different, stevie may have a diff point of view than i.
what you want is 3 phase, where you can control the height of the waves at the same time and control the speed.
the speed in time with the height creates 3 phase Harmonics, it is this 3 phase that acts like replacing the batteries very fast, and with the back emf spring effect with coils it literally pushes amps into the cell.
the amount of amps pushed into the cell  is determined by the electronics and not the cell. there will come a point to where you get so much hydrogen you don't know what to do with it.
i currently produce hydrogen at 15 to 20 volts and 15 amps, thats about 300 watts, i use no additives and produce a really good amount. you seen the video i posted on youtube? i had a leak when making that video.
« Last Edit: December 18, 2007, 01:51:50 am by hydrocars »
kumaran
« Reply #9 on: December 18, 2007, 04:57:24 am »
i can save you the trouble, if you could choose between 120 volts at 1 amp which is 120 watts, or 12 volts 10 amps wich is 120 watts, you would use the 12 volts 10 amps even though the power output is the same, amps does more work.
so you can choose 1 amps to get 120 watts using 120volts
or you can choose 10 amps to get 120 watts using 12 volts
even though the output is the same, you will get more hydrogen at lower volts more amps.
2V is just enough for electrolysis. After I power off the circuit, cell still keeps about 1.5V charge.
i say use 3 coils, and pulse none at the same time. this can be very complicated but you will find it is well worth the complication.
Car alternator is the best to do this job but need to test and find suitable inductor for different speed, that is the challenge. Hope we are going in right direction now.
Kumaran, I think the 3V is very nice to have, because the cell will get hotter with higher volts.
What the circuit concerns, Hydro is talking about a new 3 phase pwm and chokes. That connected to one cell.
I am bussy making a drawing, but I cannot find a normal drawing software with normal ic pictures.
I use ExpressPCB software (free) to draw the circuit. The software is still lack of many component. I had no choice but draw the new component. Actually I've tought about 3 phase long time ago. Yesterday, I was testing my old 3PH circuit (bread boarded) which was used for Bob Boyce resonance drive. One of the phase is not working and I will rectified the problem by today.
My idea is not actual 3 phase (120 degree). I will use 3 different inductor with 3 PWM. I will adjust each phase PW and frequency to produce 1A output which totally depends on inductor used. Then I switch on each phase one by one and see if any significant changes in input and output amps and also gas generation. Using this method, there will be clashes between phases but just wanted to see what the difference can it make to cell and circuit.
What you made is where I and Hydro are discussing about for a while by msn now.
We wanna pusch amps into the cell to. Just like you did in above schematic.
So, if you use 3 pwm's. Every pwm is 120 degrees out of phase. You get a 360 degree phaseshift, just like the alternator.
If you end up with pulsing 3 coils, you have an optimum result.
As soon as I have the schematic finished, I will send it to you.
Steveb
Yesterday, my friend gave me an old car alternator. I still think of a way to turn this alternator using speed controlled motor. I did some experiment on RotoVerter using 3PH motor previously. Not sure if I can find high speed DC motor and the speed is controlled with variable transformer. I know one of my friend has permanent magnet DC motor.
I still believe series cell (Bob Boyce design) together with this 3PH circuit will produce much better results. I will do that experiment also to confirm. I remember Bob did say he was using less than 4A to produce 6LPM using resonance drive (not really sure). Probably this is the method he used but with fixed frequency.
kumaran
« Reply #10 on: December 18, 2007, 06:19:53 am »
Bedini SSG setup part 1
kumaran
« Reply #11 on: December 18, 2007, 06:22:00 am »
Bedini SSG setup part 2
kumaran
« Reply #12 on: December 18, 2007, 06:32:53 am »
Different type of test cell used for pulse drive.
kumaran
« Reply #13 on: December 18, 2007, 06:42:29 am »
Test cell which currently being used for experiment. The cell gap is 1.2mm. Used 1.2mm nylon washer as seperator. Total of 9 holes drilled for each plate. Time consuming job but worth to keep the plates align.
« Reply #14 on: December 18, 2007, 07:01:27 am »
yes, i have not seen bobs design, with what you said it sounds like to me he found the resonate frequency of the chokes he was using hooked to the cell, this will cut the power needed in half.
i do not believe in water resonance.
kumaran
« Reply #15 on: December 18, 2007, 07:23:53 am »
Hi Hydrocars,
Bring down the input power is the key factor for high efficient while delivering same output or more.
Talking about efficiency, I saw documentary few days ago on fuel efficiency on discovery channel.
Coal : 10% efficiency
Petrol : 25% efficiency
Diesel : 45% efficiency
Natural Gas : ?
Hydroxy : ?
