Author Topic: Basic components of the Geet reactor  (Read 9838 times)
« Last Edit: August 05, 2009, 10:02:14 am by Steve »
Re: Steve's Paul Pantone replication of the GEET engine
« Reply #9 on: August 04, 2009, 22:52:05 pm »
I have been looking, Steve. Internet down here is slow and drops the connection, regularly. Monsoon type rains this time of year, and the phone lines, dial-up, leaves a LOT to be desired.
  I DID find some, but, not the one I am looking for.
« Reply #10 on: August 04, 2009, 23:43:52 pm »
Here is some of what I found.
I spent about 4 days with Paul Pantone several years ago. He told me that you can get electricity from the reactor rod. You need to insulated the exhaust pipe in the location where the reactor rod is spinning with peaces of tile and then coil a wire around the tile. When the motor is running and the rod is spinning the rotational magnetic field will energize the coil. So you could run the motor at idle and have as much electricity as you could ever use with NO back drag on the engine.
 If you hold a compass close to the exhaust pipe when running there is a strong magnetic field. The longer the engine runs the stronger the magnetic field.
 He also told me that he had a friend that did this. The results: the wire turned white hot and the multi-meter melted from the abundance of electricity. Is this true ? I have not tried it.
 I was also told how to get a generator to run on only the fumes from a battery that the generator is charging. I was unable to get this to work. I could draw this up for you if you would like.
 I was also told how to figure out what size rod needs to be in the reactor for each kind of fuel. Also running due North for 20 minutes or Vertical and not having to worry about the time limit. I have tried these two things and they work. Not sure if you know this?
 I was also able to get a mower engine to run for 4 hours and was able to hold my hand on the end of the exhaust pipe without burning myself. This is just from fin tuning the length of the rod.
« Reply #11 on: August 05, 2009, 01:20:16 am »
Another tid bit  ;D
  I've seen that before and studied it a long time. I think the GEET
 material is correct that the reactor can make such a strong
 electrostatic field that it attracts electrical charges from a good
 distance and when it works very well it is making a strong magnetic
 field also.
It is also rumored to have 200% OU  ::) ::) Don't know about that one  ::) ::)
  Pantone has been released from the Sanitarium, and, is leaving the US, very soon, according to what I read.
Basic components Geet reactor
« Reply #12 on: August 05, 2009, 10:06:31 am »
Thanks Harald!
Thats good info!
That would be great to try, is it. Create electricity! Looks like to me that the pieces are coming together....
« Last Edit: August 05, 2009, 10:25:09 am by Steve »
Re: Basic components of the Geet reactor
« Reply #13 on: August 05, 2009, 19:01:20 pm »
Steve, you should try to run it with your WFC in the "fuel tank"(antifreeze bott) and just water. maybe even through on one of those Plasma Spark set ups. if its just 20% used oil, you might be able to get it on (water/HHO) only. worth a try.
« Reply #14 on: August 05, 2009, 22:12:21 pm »
Well, It would be a pleasure to see the engine running with a Geet reactor and my wfc powering it. Then of course, the new made electricity from the geet reactor powering my wfc......
