Author Topic: Results from some tests...  (Read 59649 times)
  • Yes I got Jolted,
« Reply #16 on: July 01, 2009, 16:13:10 pm »
I don't mean to be negative here, I just want to say this:
Tube cells are very deceiving about its gas production, specially longer tubes like the one on your picture, they concentrate the gas and make it look that it is producing massive amounts of gas, but when you take real measurements, they are very disappointing.
What I'm saying is we can use just a simple visual guess on how much gas the cell might be producing, real measurements need to be made.
« Last Edit: July 01, 2009, 16:36:57 pm by electrojolt »
« Reply #17 on: July 01, 2009, 16:40:40 pm »
extremely exciting news Gauss, Thank you for sharing. I will soon have my setup operational, and i'll be trying vibrating tubes right away.
I am currently thinking of something like this for a metal tube support that will allow vibrations.
« Reply #18 on: July 01, 2009, 17:01:22 pm »
@Electrojoit, yes you are probably right, we will try to use ultrasonics soon to try to shatter some molecules in the center cylinder too. And coating is a major progress to make too. BUT the secrets are unfolding very quickly in discrete steps.
At this stage, the most important result is that a kid can do HHO from distilled/tap water with extremely limited resources. About OU yes I believe with coating and some magnetic back pulses from coils we can go further. Most important will be the ultrasonics principle, to get a firm grip on the crystals(1 mm per 2 kV is a thumbs rule I learned). They need precise tuning, can not support amps but HV and that is another reason Meyer talks about tuning. Maybe we must have HV to polarize almost all the water in the center cylinder and make it possible to shatter it too by altrasonics, it is kind of the only idea that makes real sense to me..
Anyway, I am now seeing the resemblanc between Kelvin generator, Leo Umila´s GEET modification and Stan Meyer´s pulsing. PLus, neutral and negative, mix it and ignite. Same idea everywhere, different methods. Leo Umila has rubber connections and loose parts in his modification................ ;D
« Reply #19 on: July 01, 2009, 17:02:54 pm »
Good luck Donald, I am very interested in your results!
Looks good that drawing, please report back your results asap.
« Reply #20 on: July 01, 2009, 18:11:29 pm »
Very nice to see progress in small steps here on this nice forum ;D
@Gauss
Can't wait to read all the details of your setup.
I suggest to start your own project page that keeps everything little more organized.
We all want to find information, but everything is spread all over to place.
I'm kind of stuck right now with my alternator setup 8), I'm building a new (better) pulser system.
Webmug
« Reply #21 on: July 01, 2009, 18:53:41 pm »
Hi, just got the WFC working without any coils etc. Down to 1.5 V and any freq between 500 -50 000 Hz.'
The key is the mechanics. Yes that is right. Let the cylinders or plates vibrate inside the water, there you go, the whole secret. And we tried with the VIC and our current version does not work up to 30V primary side. 1:1 transformers work well. So the Amps is key, and the shorting of the transformer is a big issue.
This is a bit confusing.  Was a transformer used or not. ?   Does "No coils"  also mean no transformer or just no chokes?
When   you said "1:1 transformers work well" I can't  tell for sure if you are referring to the VIC or to the no VIC process.
Found the key to magic by accident. We built the whole WFC thing ultra professionally from pulsers(no 555ers etc) to VICs(thanks John) to the cell mechanics with machined Delrin holders for the pipes and a large number of pro coils, still nothing worked out for us. We have suspected acoustics for a long time now.
So the other day we increased a pipe hole in the Delrin holder too much so the pipe got a bit of space to move. When we started pulsing we just got this strange tone and the whole setup was vibrating and when placing the hands around the water cylinder the vibration seemed to increase.
Spurred by this accident we decided to go "all in" for a "farmer´s solution" with just one pair of cylinders! Said and done we pushed 6 pcs of some vibrational dampening material like soft rubber between the cylinders(3 in the top and 3 in the bottom) and hanged the electric wires in a holder on top  of the water cylinder, voilà, now anything works and a kid can do this!!! Pipes have no insulation, nothing.... You can not hear the vibration but you can see the pipes are swinging inside the water a bit. No use for tuning(as far as we could see today, any frequency worked perfectly fine). Deionized water was used.
1.5 V up to any voltage works, no coils, it does not matter what you do, we throttled with the voltage and can get very big amounts of gas. And the minimum amps for production was like 0.1 Amps but that is preliminary. About why  this is working, well, vibration is everything. The vibration seems to transport the Amps from plus to minus in some magical way. A transverse wave becomes longitudinal and there is a standing wave between the cylinders shattering the water at the center point in the gap.
Believe me, we were shocked, I just did it and had no time for filming or extensive testing but in case you look at Youtube, notice all successful replicators have soft rubber spacers and just hang the cell loosely into the water. That is the key! About Stan, well, I just stick to my Piezo bolts theory more than ever tonight! This was the hole deal and the HV, Low amps I believe was about the Piezo crystlas and nothing else.
Our dimensions are(I believe): 3/4´´and 1´´ of the cylinders, the inside gap is 1.5 mm between outer wall of inner cylinder and inner wall of outer cylinder.
Pretty much seems like anything is working, we tried running 55 V input and got about 2 Amps of current with 50% square wave duty cycle. That means about 55 W input. I believe with more cylinders we will get much better efficiency. We have no measuring equipment for efficiency yet but we will get it, I am sure we can get OU but with coating I believe it will be much better. So many more things to do...
So let me summarize.   And please correct me where I may have misunderstood.
1. There are no coils.  ( I assume no coils also means no transformer.  The Meyer blocking diode was not mentioned so I also assume that was included in the "etc" and is not used. )
2. The tubes are 1" and 3/4" with spacers made of  2mm thick EPDM 1722.  This gives a gap between the tubes is  about 1.5mm.
3.  The length of the tubes is not given.
4.  The tubes are suspended from the input wires down into the water reservoir where they hang loosely.
5.  There is no insulation or coating on either tube.
6.  The water is de-ionized water.
7.   The input is a 50 percent Duty Cycle square wave from 500-50,000 Hz.
8.   The  minimum applied voltage is 1.5v  for gas production
9.  Gas is produced at a seemingly  increased vs Pure DC  regardless of applied frequency.
      In other words,  any resonance involved is not affected by applied pulse frequency.
10.  No actual gas production levels we taken
So basically there are 2 tubes with rubber spacers suspended in deionized water
with pulsed DC applied.
Gauss,  please correct anything above that I misunderstood.
Goey
« Reply #22 on: July 01, 2009, 19:22:07 pm »
@Gauss
The brown muck is not from the water, and, not from the rubber....it is rust!
Any time you use amps (electrolysis)...you will have metal ions traveling out of the metal. In my experiments it is most noticeable from the + to the -...the negative turns dark colored...while the positive looks all sparkly and pitted.
This does not hold true to what Meyer said about the electrodes not disintegrating...the only way to keep your electrodes alive in an electrolyzer is to swap polarity back and forth.
« Reply #23 on: July 01, 2009, 21:57:21 pm »
I wonder if you took your outer tube and put a little sealer (like that plastic dip) on the ends so the inner tub could float freely without fear of short with outer tube.
What do ya think?
Robert
