Author Topic: Kathode or Anode  (Read 3740 times)
Kathode or Anode
« on: June 07, 2009, 12:42:37 pm »
Ever asked yourself: Plus on the inside or on the outside tube? Even Stan switched in his carrier from tubes...
In an electrolytic cell, the cathode is where the negative polarity is applied to drive the cell. Common results of reduction at the cathode are hydrogen gas or pure metal from metal ions. When discussing the relative reducing power of two redox agents, the couple for generating the more reducing species is said to be more "cathodic" with respect to the more easily reduced reagent.
In a galvanic cell, the cathode is where the positive pole is connected to allow the circuit to be completed: as the anode of the galvanic cell gives off electrons, they return from the circuit into the cell through the cathode.
http://en.wikipedia.org/wiki/Kathode
In physics or electronics, a cathode is an electrode that emits electrons into the device.
Re: Kathode or Anode
« Reply #1 on: June 13, 2009, 21:49:01 pm »
hi Steve
  yes in a galvanic cell, it is better to use the 'electron flow'
aussepom
« Reply #2 on: June 14, 2009, 02:17:00 am »
Stan doesn't use a cathode then, neither emit electrons  ;)
« Reply #3 on: June 14, 2009, 09:10:41 am »
can people stop trying to relate this to standard electronics and TRY  top relate it as 180 OUT //////////////////////////////ALSO WITH the logics and past RULES that have been set????can we start off with a clean slate with non existant  things that involve new IDEAS  ???? the unkonown that hasnt been read or said to main population stream???? lets really step out side the box AS A GROUP INSTEAD OF THE FEW because if we dont the only one who will suceeed  are the ones who care about politics and personal gains>? ant thats the truth
outlawstc
« Reply #4 on: June 14, 2009, 10:46:08 am »
« Reply #5 on: June 14, 2009, 11:52:06 am »
Hi Donald,
I know that there are 2 camps fighting to prove that they know what Stan did.. ;)
The non amps and the amps researchers.
Can you explain then to me the follow testresults?
« Reply #6 on: June 14, 2009, 14:05:57 pm »
Amp restriction isn't non-amps.
The graph doesnt state if 12.5V is applied to the cell or to the transformer.
 :-\ 0 khz is steady DC
« Last Edit: June 14, 2009, 14:47:58 pm by Alan »
« Reply #7 on: June 14, 2009, 18:25:33 pm »
i agree.
0khz = DC
Hahahahahahaha , good find!
