Author Topic: Voltage without current  (Read 6895 times)
« on: May 30, 2009, 08:41:46 am »
voltage travels at the speed of sound LIGHT!
current (electron flow) travels at a fraction of a centimeter per second
the speed current travels depends on the material, in copper it travels extremely fast, in semiconductors / stainless steel / resistive wire it travels slower
the time between the application of voltage to the beginning of current flow is finite, and depends on the material, and according to some is called the "relaxation time"
rapid on-off switching of voltage application for a duration shorter than the "relaxation time" of the specific material being used will result in application of voltage without any current flow
thus is the basis of the following 3 devices, and most definitely hundreds more
1. The Tesla switch
2. The VIC = The electron bounce phenomenon
3. Tom Beardens Voltage Collector
« Last Edit: November 17, 2009, 18:50:06 pm by Donaldwfc »
Re: Voltage without current
« Reply #1 on: May 30, 2009, 08:48:45 am »
Good post!
« Reply #2 on: June 01, 2009, 11:57:18 am »
@Donald
Mostly correct...except voltage travels at the speed of LIGHT ;)
And, while yes amperage physically moves very slowly if you focus on the path of a certain electron...however, the event is a cascading chain reaction, where the electrons all the way the way at the end of the line (right before load) start moving quickly (but at a slow rate)...but anyway...you are correct on everything else.
« Reply #3 on: June 01, 2009, 13:19:27 pm »
Bedini: cutting off the signal after around 90 degrees when current starts to flow, by using the trigger coil on the transistor (correct me if I'm wrong)
« Reply #4 on: June 01, 2009, 14:59:58 pm »
i've heard the speed of light is variable and by no means limiting, supposedly speeds of 50c have been reached, i wouldn't rule it out
« Reply #5 on: June 01, 2009, 20:15:18 pm »
the speed of light is variable.. constants are for closed minds that dont understand that everything is variable. except for things like geometric harmonic codes like finding a perimeter of a perfect circle. 3.14..  the speed of light can be slowed down due to resistance... for example what color is the morning and evening skys? the color is light traveling slower due to its path taken to reach you it is traveling through more atmosphere.. which equals more resistance.
« Reply #6 on: June 01, 2009, 20:25:36 pm »
yea, never be afraid to accept everything you know about something is wrong, it's the easiest way to learn the truth and sort through bs.
anyway, it only really matters if we can put this stuff to use, and figure out how this stainless steel wire works, and this electron bounce phenomenon works, because the concept is that difficult to understand... apply the voltage and switch it off before the electrons move, this preserves  your source energy... it all ties into high voltage direct current pulses... the secret to everything, this is just one more clue that shows what the pulses need to accomplish, and also that resistive wire, instead of copper wire, can hold some secrets
« Reply #7 on: June 03, 2009, 13:36:07 pm »
this is on the last page of the tech
Note 1) The Electron Inhibiting Effect (631) of Figure (7-6) to cause "Electron Clustering"
(Grouping/collecting negative charged particles at a given point) (700) of Figure (7-9) to produce
''Negative Voltage Potential" ( B- ) at one side of Water Gap (Cp) of Figure (7-8) is accomplished by
low electrical power input (Tab 38) when Choke-Coil (62) of Figure (7-1) magnetic field (FL2) (690)
of Figure (7-8) during pulse on-time (49) impede "Electron-Flow" since electron mass is composed of
electromagnetic matter which interacts with magnetic field strength (FL2). Capacitance Charging
Effect (628) prevents amp influxing away from Water Gap (Cp) in a similar manner ... producing
"Electrical Stress" (SS' - RR') (B+/B-) across Water Gap (Cp) since both Choke-Coils (56/62) conducts
voltage potential (Negative or Positive) during pulsing operations.
Note 2) In determining volumetric sizing of the atom, Neutrons Clustering only enlarges the nucleus
surface area since the additive Neutron (s) exhibits no electrical charge to deflect or change the orbital
spin-velocity of the atom electrons.
Note 3) Universal Energy (9) of Figure (5-10) being a continuous energy potential (source) (C2)(CONSTANT SQ.)
coming into our space continuum and creating and sustaining/maintaining our expanding universe, as
so extrapolated via mass equation E=MC2. Whereby, Universal Energy (C2) having native intelligence
to create mass (M) (to cause electromagnetic wave-vectoring - photon structuring _ electron to proton
grouping to form atoms - molecular arrangements to bring-on chemical processes to sustain life) which,
in turns, emits radiant energy (E) under different stimuli conditions ... example, particle oscillation as a
energy generator by way of "Electrical Stress".
