Author Topic: How to Modify output Frequency of a Husky 400 Watt Inverter  (Read 8526 times)
  • Yes I got Jolted,
This new topic is to attempt to adjust the output freq on a Husky 400 watt inverter.
I want to Thank Komatek for supplying the inverter.
Re: How to Modify output Frequency of a Husky 400 Watt Inverter
« Reply #1 on: May 06, 2009, 23:35:25 pm »
Nice work, Electrojolt.
Thats a nice way of getting 110V /400watts in a widt range of frequency.
  • Yes I got Jolted,
« Reply #2 on: May 07, 2009, 22:10:44 pm »
Yeah, just another tool to help us experiment with making HHO.
I will be posting the how to soon.
It is very simple, just need to change a resistor from 100K to 10K, and add a Potenciometer inline with the new 10k resistor.
for lower than 60hz will also need to replace a 0.1uf cap with a bigger one, maybe 1uf. will have to test this.
  • Yes I got Jolted,
« Reply #3 on: May 09, 2009, 06:04:42 am »
Ok, I was able to mod the husky inverter to output frequencies from 40Hz to 650Hz.
Using a transformer and a some caps we can also get a pretty good sine wave.
« Reply #4 on: May 09, 2009, 07:05:08 am »
So what exactly can you do with this?
  • Yes I got Jolted,
« Reply #5 on: May 10, 2009, 00:05:41 am »
Well, just another tool, to experiment with.
« Reply #6 on: May 10, 2009, 03:36:08 am »
so it converts DC to AC, and now you can vary the frequency, but you can't make gas with AC, so you'll rectify it, then you'll have pulsed DC with variable frequency, but it only goes up to 650 Hz, which doesn't give much room to find resonance.
I'm just trying to understand it, nothing against it, in fact because of this i finally understood how capacitors and resistors work in a circuit to control frequencies!
  • Yes I got Jolted,
« Reply #7 on: May 10, 2009, 16:14:35 pm »
Well, I don't know if this will help, but BOB B. said several times that he used a modified inverter 400hz to 600hz to power his toroid cell...
So for those still trying to test BOB B. system, this should help.
