Author Topic: This Video  (Read 9781 times)
  • Yes I got Jolted,
Re: This Video
« Reply #24 on: May 03, 2009, 05:03:17 am »
so if he is using a wave then the reason for gating would make sense...... i am seeing it as a 5 thousand cycles a second meanin one positive pulse and one negative pulse....(a cycle)......super imposing a half hertz gating signal will then create a 2500 UNIPOLAR pulses with a 50% duty cycle since the gating switches off on the negative half of the cycle....he uses the word discrete which means seperate so 2,500 seperate pulses.......interesting.
any comments on this electrojolt?
-----> Well, by using a .5 Hz Gating on a 5Khz pulsing, that means the circuit will be pulsing 5Khz for  1 second, and during that one second, there will be 2500 On pulses.
alright so let me clear this up here.....so there are 5,000 cycles a second but the gating is half a cycle a second (let's say the negative half of the cycle) so there will be then 2,500 cycles in between every half cycle of nothing.
so then if meyers is using pulses as input then there are 2,500 on pulses with 50 percent duty cycle for half of the cycle and the other half of the cycle is off.
sooo:   _________2500 with 50% duty cycle_________2500 50% duty cycle_________2500 50% duty cycle
and the above image would be 3 full cycles.
and that is what is going into the primary.
my drawing is terribly confusing seeing that i simplfied it down to 3 hertz when in reality there are 15,000 cycles going on in that drawing.
Yes, I agree, that is what the Patent says.
Re: This Video
« Reply #25 on: May 03, 2009, 05:04:18 am »
thank you electrojolt for helping me.....i kept visualizing hertz although it is in kilohertz......this is reflected in my drawing.
thank you very much i appreciate it.
Re: This Video
« Reply #26 on: May 03, 2009, 05:05:09 am »
try this
i think you have to consider that we are always talking about unipolar pulses
we know the primary gets 50% duty cycle unipolar frequency with gates
Re: This Video
« Reply #27 on: May 03, 2009, 05:08:49 am »
hell yeah! exactly!
and that is what pulses the primary!
Re: This Video
« Reply #28 on: May 03, 2009, 05:14:22 am »
try and figure out that math lol
10 Hz + 1 Hz Gate = 5 Hz [all 50% duty)
it's not normal math, it's wave form math, if i wasn't drawing it i would have made a mistake (in fact i did before i drew it, see the scribble)
Re: This Video
« Reply #29 on: May 03, 2009, 05:44:43 am »
haha your right but i know what you mean
that 1hz pulse is very looong.
but you get the concept.
  • Yes I got Jolted,
Re: This Video
« Reply #30 on: May 03, 2009, 06:17:56 am »
Now there is only one problem..
I did this last year, and didn't see any good results.
but I didn't have a VIC, my understanding was that using this signal, it would allow the WFC to build up some charge, to high voltage, but that was not the case.
Re: This Video
« Reply #31 on: May 03, 2009, 06:35:42 am »
yes i have also had no success also....it's not that simple.
i think it has to do with producing the double pulse.....the frequency of the double pulse production .
tomorrow i will have johns coil and will try the last bifilar connection.
i always have my fingers crossed.
i seem to have the same problems demartin faces with the 2 different connections.......so it is narrowing down very precisely.
