Author Topic: Underground info  (Read 16838 times)
Re: Underground info
« Reply #32 on: March 28, 2009, 07:27:21 am »
very interesting dankie.. where can i buy one of these body resonators?. sounds relaxing.. check out this definition..
Spin polarization is the degree to which the spin, i.e. the intrinsic angular momentum of elementary particles, is aligned with a given direction. This property may pertain to the spin, hence to the magnetic moment, of conduction electrons in ferromagnetic metals, such as iron, giving rise to spin polarized currents. It may also pertain to beams of particles, produced for particular aims, such as polarized neutron scattering or muon spin spectroscopy. Spin polarization of electrons or of nuclei, often called simply magnetization, is also produced by the application of a magnetic field, thanks to the Curie law and it is used to produce an induction signal in Electron spin resonance (ESR or EPR) and in Nuclear magnetic resonance (NMR).
Spin polarization is also important for spintronics, a branch of electronics. Magnetic semiconductors are being researched as possible spintronics materials.
The spin of free electrons is measured either by a LEED image from a clean wolfram-crystal (SPLEED) or by an electron microscope composed purely of electrostatic lenses and a gold foil as a sample. Back scattered electrons are decelerated by annular optics and focused onto a ring shaped electron mulitplier at about 15°. The position on the ring is recorded. This whole device is called a Mott-detector. Depending on their spin the electrons have the chance to hit the ring at different positions. 1% of the electrons are scattered in the foil. Of these 1% are collected by the detector and then about 30% of the electrons hit the detector at the wrong position. Both devices work due to spin orbit coupling.
« Reply #33 on: March 28, 2009, 07:40:55 am »
a little thing i wrote up. i call it       polarity vice versa.
    for every question theres a answer, for every answer theres a question there the same in relation but theres two  differences involved to get either action  , distortion and clarity. when you are born, distortion of all reality is at its highest. its the simple times of life, the begining.. the mind is not full of mixed signals created from experiance that happens in time..  its blind. as we go through life we find clarity in many things and it gives us a sense of enlightenment and or a sense of troubles... distortions and clarity can create gain working in opposition to each other. the gain  is wisdom and the truth. one step forward towards the question. brings you one step closer to the truth. hey it may be a bumpy road but its builds character. what shows the truth? reflection. they make us walk in circles now days nothin but  distortion.  some of us have intuition gods people.. some have ignorance the devils infantry. there is so much truth in this .if you dont understand it read it again and again. since each time you read it, it shall bring you one step closer. to the truth. stan meyers  work and the worlds based off it..
i hope you like my riddle.
outlawstc
« Reply #34 on: March 28, 2009, 16:07:33 pm »
that little riddle explains how it works. energy exist in many forms  and theres allways difference.. but the difference brings on attraction in natural law.  they pull on each other.. thats where the new net gain comes from.. there a team together...   the world has been so distorted that are differences created hate/ repel, such as racist.. why??? because we are being distorted everyday by many encounters. by what? standards, regulation and so on. so much turbulance... you see everthing applys to these rules when it comes to action/ life.. but they all take time..  some winds are faster but thats because the differences are higher(excitment). some winds are slow they are lower differences (bordem).  turbulance comes from imbalance.  and while all this is happening you are given one point of observation. the body. relativity is understanding this????
outlawstc
« Reply #35 on: March 28, 2009, 18:24:57 pm »
what do you see in this picture?
« Reply #36 on: March 28, 2009, 19:20:27 pm »
ok i see what this pic is saying.. so i look up the painter biography and here are some clips.
his name is Isaac Abrams
He begins his work with a series of loosely conceived juxtapositions and then discovers in those juxtapositions the metaphysical and cosmic concepts which are so often expressed in his art.
His works are sudden leaps into unknown spaces, into free-floating gravityless existences, where angels and demons, concepts and conceptions appear and disappear, where paradoxes proliferate and where each viewing of the painting may bring to the viewer a new and different cross combination of the ele- ments within.
His intentions are to create a painting viewable at any distance from inches to yards or dozens of yards; a piece having a vital life which is not dependent on a single point of view or a single conception of what was within.
A Jungian psychoanalyst, for example, has said that Mr. Abrams' works relate to certain archetypical experiences which are often seen in the dreams and fantasies of her patients; a physicist sees various assertions of the latest thinking about the gravitational effects of large bodies on space, time and the "shape" of the universe.
Mr. Abrams feels that he is an open channel. His work is not limited by his own knowledge. He is open to third forces; the first being himself, the second being the painting; and the third being the forces of unconscious cross-connection of all thoughts into one great mind. Having experienced this unity of all thought forms into the one thought form, Mr. Abrams is capable of reaching into the many areas of human experience, to snatch from the pool of the collective consciousness of all minds, extraordinarily acute perceptions.
http://www.rogallery.com/abrams_isaac/abrams-bio.html
outlawstc
« Reply #37 on: March 29, 2009, 20:56:17 pm »
i added some more to my little riddle...
For every question there’s an answer, for every answer there’s a question there the same in relation but there are two differences involved to get action, distortion and clarity. When you are born, distortion of all reality is at its highest. Its simple times of life, the beginning... the mind is not full of mixed signals created from experience that happens in time... its blind. As we go through life we find clarity in many things and it gives us a sense of enlightenment and or a sense of troubles... distortions and clarity can create gain working in opposition to each other. The gain is wisdom and the truth. One step forward towards the question, brings you one step closer to the truth. Hey it may be a bumpy road but its builds character. What shows the truth? Reflection. They make us walk in circles now days, surrounded by nothing but distortion. Some of us have intuition gods people... some have ignorance the devils infantry. There is so much truth in this .if you don’t understand it read it again and again. Since each time you read it, it shall bring you one step closer. To the truth, one step closer to intuitive instincts and also take you one step away from ignorance at the same time hey its duality vice versa!! life has to many variables and complexities to predict and prepare ahead of the time in most cases.. so the only thing you can do is BE prepare for the ride 24/7.. and in the present time of relativity it seems like it might get ruff. so hold on tight and dont shit yourself. the truth is im as real as they come these days haha.. what does your intuition say? i say bitch dont judge me see its vice versa lol
thats the theory of relativity in my words.. and stans tech  works off of the vice versa duality in nature..
that is the most important thing i think i will ever be able to write on paper in my life when it comes to lifes actions in there simplest forms that creates our complex life. from our perspective. its the dualitys of multiple forces that paint the canvas..  stan set up a controlled environment for specific duality forces.
cheers
outlawstc
« Reply #38 on: March 30, 2009, 09:22:56 am »
in this drawing i made.. it gives a example on a atomic level how they determine a cycle..  also under it i give an example of what beardon is talking about when he says pumping the dipole..   read my quote as a whole understand it.. it sheds light on everything... when you pump a dipole its sending light one way and electrons the other way..  when being done under rectified emf it can cause displacement in things..   i think depending on what side of the equator your on  determines your antigravity force of use for purpulsion (light or electrons).. when it comes to levitation. think about it.. if the south pole is negative.. why do you think theres huge tropical rain forest.. there negative  land charge of the south pole pulls in more light.. it gives the south hemisphere  more vividness in colors.. look at how colorful there plants and animals are down there they are getting more light saturation.. also the land probly gets a positve skin effect  which might saturate there air with more carbon then the north. while  the north pole we build up with electrons on this side because are positve land north hemisphere attracts them.we get a negative skin effect.. causing dryness. cold winters. less color..  negativity. then you look at the southern hemisphere.. how often do you hear of any conflict down there? lol
outlawstc
« Reply #39 on: April 18, 2009, 20:17:09 pm »
That pic I recognize from mr John Keely´s work. Read him, he is perhaps the best experimental physicist that ever existed, also check out keelytech.com - Keely was a giant and www.witts.ws are following in his footsteps with their work on crystals and hf dissonance etc. I believe witts i the best group out there, by far. Hopefully they will get some funding from people and get stronger, Sir Timothy Thrapp has been persecuted for 20 years, simply because he is the best one I believe.
