Author Topic: Gated Pulse Frequency Generator Schematic  (Read 36875 times)
Re: Gated Pulse Frequency Generator Schematic
« Reply #64 on: December 10, 2012, 17:46:13 pm »
Who built the gated pulse gen like in the patent or like Tony and worked?I tried bouth crkts on breadboard and pcb and none of them worked....
« Reply #65 on: December 10, 2012, 18:01:05 pm »
Did you hook it up to a powersupply?  ;D ;D ;D
Just kidding......
Do you see a squarewave on yr scope, without having a load to the circuit?
« Reply #66 on: December 10, 2012, 18:07:53 pm »
http://www.ionizationx.com/index.php/topic,2523.msg23643.html#msg23643
Check if you have version 1 pcb of Tony.
Regards
« Reply #67 on: December 10, 2012, 18:09:41 pm »
Just kidding......
I see a square wave but not the gated signal from the 9xb,and when i increase duty it loses signal
« Reply #68 on: December 10, 2012, 18:14:35 pm »
Regards
the gating with 7402...and the rest is the same like in the patent
« Reply #69 on: December 10, 2012, 19:12:12 pm »
this is the output on pin 8 of the 74122
« Reply #70 on: December 10, 2012, 23:51:32 pm »
The gate is only a mean for controlling gas output, in later design actually it is probably substituted by the injectors signal... think about it...
« Reply #71 on: December 10, 2012, 23:53:21 pm »
What about the stepcharging?
