Author Topic: GODS ULTIMATE POWER FOR HUMANITY THEORY  (Read 7176 times)
Re: GODS ULTIMATE POWER FOR HUMANITY THEORY
« Reply #8 on: April 05, 2009, 17:50:44 pm »
Amorphous silicon (a-Si) is the non-crystalline allotropic form of silicon. Silicon is a four-fold coordinated atom that is normally tetrahedrally bonded to four neighboring silicon atoms. In crystalline silicon this tetrahedral structure is continued over a large range, forming a well-ordered lattice (crystal). In amorphous silicon this long range order is not present and the atoms form a continuous random network. Not all the atoms within amorphous silicon are four-fold coordinated. Due to the disordered nature of the material some atoms have a dangling bond. These dangling bonds are defects in the continuous random network, which cause electrical behaviour. If desired, the material can be passivated by hydrogen, which bonds to the dangling bonds and can reduce the dangling bond density by several orders of magnitude. Hydrogenated amorphous silicon (a-Si:H) has a sufficiently low amount of defects to be used within devices. However, the hydrogen is unfortunately associated with light induced degradation of the material, termed the Staebler-Wronski Effect.
« Reply #9 on: April 05, 2009, 18:13:21 pm »
"Under the microscope, I found that snowflakes
     were miracles of beauty; and it seemed a
     shame that this beauty should not be seen and
     appreciated by others. Every crystal was a
     masterpiece of design and no one design was
     ever repeated., When a snowflake melted, that
     design was forever lost. Just that much beauty
     was gone, without leaving any record behind."
Wilson "Snowflake" Bentley 1925
http://www.cienciateca.com/stssnow.html
« Reply #10 on: April 05, 2009, 18:36:25 pm »
The piezoresistive effect describes the changing electrical resistance of a material due to applied mechanical stress. The piezoresistive effect differs from the piezoelectric effect. In contrast to the piezoelectric effect, the piezoresistive effect only causes a change in resistance; it does not produce an electric potential.
Piezoresistive silicon devices
The piezoresistive effect of semiconductors has been used for sensor devices employing all kinds of semiconductor materials such as germanium, polycrystalline silicon, amorphous silicon, and single crystal silicon. Since silicon is today the material of choice for integrated digital and analog circuits the use of piezoresistive silicon devices has been of great interest. It enables the easy integration of stress sensors with Bipolar and CMOS circuits.
This has enabled a wide range of products using the piezoresisitve effect. Many commercial devices such as pressure sensors and acceleration sensors employ the piezoresistive effect in silicon. But due to its magnitude the piezoresistive effect in silicon has also attracted the attention of research and development for all other devices using single crystal silicon. Semiconductor Hall sensors, for example, were capable of achieving their current precision only after employing methods which eliminate signal contributions due the applied mechanical stress.
[edit] Piezoresistors
Piezoresistors are resistors made from a piezoresistive material and are usually used for measurement of mechanical stress. They are the simplest form of piezoresistive devices.
[edit] Fabrication
Piezoresistors can be fabricated using wide variety of piezoresistive materials. The simplest form of piezoresistive silicon sensors are diffused resistors. Piezoresistors consist of a simple two contact diffused n- or p-wells within a p- or n-substrate. As the typical square resistances of these devices are in the range of several hundred ohms, additional p+ or n+ plus diffusions are necessary to facilitate ohmic contacts to the device.
« Reply #11 on: April 09, 2009, 15:14:10 pm »
Haven't read much of your posts here lately, too much for me atm :P
but you said matter and light are the same, and I came to a similar conclusion with some open questions:
an electron
http://www.youtube.com/watch?v=IPdO-NIUuEo
is clearly a standing wave.
Matter is a standing wave on the substance of space-time. Spacetime gets concentrated by C2 giving it the properties of matter, this costs and thus stores energy.
What is gravity: imagine a rope with both ends tied to rubber bands, now swing
the center of the rope until standing waves occur, the ends pull the rubber bands towards the inside.
Standing waves of matter is pulling space-time's elastic properties inwards the same way, as a result a gravity (potential) occurs.
Light is a traveling wave, this is the reason light flows over the space-time surface (with zero resistance, defined by the waves E and B and space-time's u and m) and matter doesn't.
Light isn't a standing wave, thus no properties matter and zero mass is measured.
Positrons are anti matter, meaning? negative mass makes no sense, it must have something to do with the properties of  its standing wave.
Instead of pulling (contracting) space-time, it expands it?
What keeps a standing wave in motion? Some interlocking mechanism or a constant flow of energy... self energy?
Can its oscillating source interact with traveling waves (light), thus increasing the energy? Is this the way matter absorbs photons? No one knows what photons are, but everyone thinks he/she knows. They are a huge mystery.
Are light and matter on opposite sides of the same coin, with the only difference the type of wave?
Thus ends my brainfart.
« Reply #12 on: April 09, 2009, 16:21:02 pm »
I like your brainfart. Well written.
« Reply #13 on: April 09, 2009, 16:54:52 pm »
Haven't read much of your posts here lately, too much for me atm Tongue
photons are the vice versa of electrons.. vice versa as we know are things like hot cold, wet dry, day and night.  so we can concled they are opposite states. ok the opposite state on the atomic level create vise versa effects to atomic charged particle positve and neg. making them have GRAVITY in opposite directions..
the type of electric current we use in todays world(alternating current ) is what i call turbulent current when being used and we know of them as amps..  as you should know 125 volts AC has 1 hot leg 1 neutral, and a ground.. the neutral isnt hooked to their stator neutral of the generator at the power plant .. so there for it isnt a closed loop circuit what so ever.. they rely on pumping amps down a wire for a source of power down 1 hot leg, through the load, and then into earth ground.
tubulent amps is where the heat comes from in conventional electric. see since they use 1 hot leg to send there power it is pushing electrons 2 times further then pullng back.. they travel 2 times further because neutral is like a dead short on the load side..  they use earths attraction to stabilization to help the load move down the line.. well every time you switch directions in 1 hot wire you are causing the copper atoms protons to flip flop back and forth, when they do that it causes heat by means of friction on a atomic level.  pole flopping of the protons of some sort..  proton matter is just like earth.. it is positve charged but has neutral effect as well.. notice how protons and neutrons cling  with attraction... well we humans are neutral charged and what do we cling to? earth!!!  so i would have to say the copper protons are pole oriented determined by the direction of orbiting electrons.
resonance in stans set up is learning how to use electric in its tru calling.. a biderectional flow.. which would be putting a one direction flow for electrons.. your not pulling them back any more just push push push push.. and light is getting pushed pushed pushed in the other direction in same relative time although it may not be as much push as vacuum.. the rectifier is like a back flow preventor..  so once you figure out how to push one way with the alternator.. you know that the negative choke is becoming condensed with electrons while the positive choke is where the negative choke got its electrons from.. so it is short of electrons to be atomicaly neutral.. it has been put in a higher vacuum energy state.. which is positve.  the electrons being pulled out were traded for light.  so we know the positve goes into vacuum state and electrons are in a pressure state.. now you must understand balance of building states.. if you dont build them in a even in a  relative manner then you will created turbulent amps across the load which is the water.. waters viscosity has a harder time remaining pole oriented under unbalanced voltage fields..  the little amount of amps stan used was enough to keep them polarized while voltage performed work. im gonna draw up the difference in turbulent and non turbulent here soon.
« Reply #14 on: April 09, 2009, 17:27:41 pm »
an electron
Very nice brainfart .
So how it is we do this now heh ?
« Reply #15 on: April 09, 2009, 18:01:30 pm »
for every action one trade take place, 0 and 1 polar matter displace. 0's the light and YOU ARE THE 1, what it amounts to is divinity..
lol part of a song i wrote..
in my mind for every action one trade takes place
makes me think back to 2 pac days
live by the gun die by the gun
what he'd  say.
the deal is we in the matrix and
for every action one trade takes place.
1 and 0  polar matter displaced
0 is light and you are one and what it amounts to
is divinity and in todays worlds filtered by luminosity
 they dont share the gift
moneys the artificial  switch
1913 freedom got ditched
so take your turbulent disturbants
go buy some detergent
and make your own suds
im ready to grab my guns
play elmer fud  and go have some fun
how deep does the wabbit hole go
thats what im out to know.
come out to playpesky wabbit
visualizing a gun to his noes
all i see is visual distortion
my intuition says all seeing eye
causeing govenment collusion
hiding the fusion in lifes illusions
as pastor troy say's
look up in the sky nigga we rich..
find your third eye and open it
this is for the deaf dumb and blind
please dont make me flip my mind
from positive to negative
we're all riders of the same storm
which makes us dividend as well as innocent
