Author Topic: Possible ways to reduce amps and increase gas  (Read 7072 times)
« on: March 28, 2009, 16:23:19 pm »
Have had an idea some time and that was/is to use engine waste heat since the thermostat is 92 degree. C
So i tested a small cell in straight tapwater today with different temperatures and measured the amp consume.
1. Tapwater at 16 degree.C  used steady 0,48 amps and the output was not measured, but output was remembered for the next test.
2. Heated tapwater at over 90 C. to start with and about 75 at end of test. Amp was 0,42 and the gas output was close to doubled according to test number 1.
    The bubbles looked also bigger with hot water.
Hot water reduce amps and give an higher gas output?...
This was interesting :)
« Last Edit: March 28, 2009, 16:39:46 pm by WaytoGo »
Re: Possible ways to reduce amps and increase gas
« Reply #1 on: March 28, 2009, 16:57:28 pm »
it makes sense.. heat in the water during  a cold process to the water.. the cold process (voltage)is trying to throw the atoms electons out of balance with magnetic forces into a expanded state. the heat in the water is a tempature difference. and heat makes water go further out of balance  into a expanded state.. so that creates 2 relative forces that are enhancing each other and working together??
outlawstc
« Reply #2 on: March 28, 2009, 17:03:50 pm »
unless thats a steam resonator you got , the energy you would have to spend to get that water hot is enormous .
Not such a good thing sorry .
« Reply #3 on: March 28, 2009, 17:10:30 pm »
The engine get hot when it is running anyway so i am not spending energy... I'm just using it instead of wasting it.
« Reply #4 on: March 28, 2009, 17:13:47 pm »
Amp reducing is the waytogo ;D, and i have two more amp reducing ideas at the moment.
One of them is tested to work fantastic a while ago, and the other is not tested yet because it must be build first and i wonder often why Stan never did this!!!
It is so good it is worth a patent.... and does not exist anywhere because i have invented it.
The long term idea is to combine hot water from engine waste heat with these two new amp reducing ideas and make more hydrogene than ever at a close to zero cost.
I will share my ideas when i got the results for sure and if this forum exist and you are nice to me.
« Reply #5 on: March 28, 2009, 17:20:55 pm »
if you do this at high temperatures then you are going to get water vapor in your gas output, when you are measuring your output be sure to bubble through cold water, this will take water vapor/steam out of the "gas", and give you a more accurate reading, also hot gas is less dense, so after your run it through a cold bubbler to take out the water vapor, the gas volume will shrink because of the lower temperature. if you then figure hot gas is more efficient in burning in the engine, then you can always reheat the gas with the heat from the exhaust.
« Reply #6 on: March 28, 2009, 17:26:45 pm »
  this is a good example on recycling energy .. but to say you wounder why stan didnt think of it are you sure he didnt? i mean where was his intake manifold located? stan could have had it where the manifold going to the injectors was being heated by radiant  heat from the block..  and he would of know that the induced heat could only further his amplitude before seperation.
outlawstc
« Reply #7 on: March 28, 2009, 17:41:33 pm »
  this is a good example on recycling energy .. but to say you wounder why Stan didn't think of it are you sure he didn't? i mean where was his intake manifold located? Stan could have had it where the manifold going to the injectors was being heated by radiant heat from the block.. and he would of know that the induced heat could only further his amplitude before separation.
outlawst
Hi Outlawst,
I am agree to what you say, but i am working on two other amp reducing devices that i am surprised Stan didn't think of or anyone else.
Best regards
