Author Topic: Info  (Read 38659 times)
Re: Info
« Reply #80 on: May 21, 2009, 15:18:01 pm »
some more
can't remember I saved em
Re: Info
« Reply #81 on: May 21, 2009, 15:20:28 pm »
Chargin water.
aetheric fire from charged water..
Re: Info
« Reply #82 on: May 21, 2009, 20:57:49 pm »
Radiant, got any new insights or ideas regarding your video's?
it is strange what the carbon corrosion is doing, more power is released - because of P = I^2*R -> more resistance, more heat?
Re: Info
« Reply #83 on: May 21, 2009, 21:22:59 pm »
Carbon does burn, it is used in power plants instead of coal sometimes. They just grind it into a fine powder and inject it into the boilers.
Re: Info
« Reply #84 on: May 21, 2009, 22:26:43 pm »
Those are some pretty amazing videos .
Thx you Alan
Re: Info
« Reply #85 on: May 22, 2009, 12:15:25 pm »
I have made a version of a homemade welder (supposedly what Dan Dingel was welding with)
It is based off this german drawing from Dingel's stuff. It is almost exactly like my arc experiment...it uses about 40 watts and melts steel.
(http://i175.photobucket.com/albums/w152/Jdub6d9/danieldingel1.jpg)
I find that resistance is needed to get the effect...it is the same mechanism...I have to "strike an arc" by direct contact then pull away...it's much easier to do at 48v. Once I strike it a BEMF HV spike breaks down the air allowing the next forward EMF conduct through the ionized air. Over and over...it's a spark oscillator, meaning it is running at many frequencies (white noise spark gaps supply many frequencies)
I will be testing this circuit much more tomorrow....should get a video too...but it looks like a promising system.
As for my early videos...they should only be appreciated for the certain effects...as for my explanations back then...they were a lil lacking (I understand it much better now)
Re: Info
« Reply #86 on: May 22, 2009, 18:37:59 pm »
Plz make that video so I can see how fast and clean this cuts through steel .
This cant cut anything non conductive right  ???
Re: Info
« Reply #87 on: May 22, 2009, 21:13:13 pm »
No problem thank radiant for making them :)
the shock group video shows water charged with what meyer called universal energy. i think.
It is striking how all these devices use a similar techniques - looking forward tto a demonstration.
Does your understanding include energy from the vacuum and excess energy?
