Author Topic: Defining the word "opposite"  (Read 22927 times)
Re: Defining the word "opposite"
« Reply #40 on: March 01, 2009, 06:55:18 am »
i just didnt finish adding the rest.. all secondarys would be hooked to it.. and create more of a pure dc like we see when all three phases are joined.. but whats good about this idea is you can see how the multi-spools can be used in that manner.. using the none resistive copper for a air gap sounds like a good idea... voltage goes for everthing at once off 3 chokes.. each one plays a role in the air ionization and water polarization.. and even electron extraction since that is simple.. just need a isolated high voltage positve to do that.. it will pull the electrons in and you could power led with them and slow them down or do electrons burn off into light?.. when they flow into a wire that is missing alot of electrons it will create amps that can be burnt off through leds.... im glad to see we have some people studying the gas processor i havent focused on that aspect at all.
page 152 validates what i have been saying for a while now..
"Magnetic Field Coupling (71) of Figure (7-9) entering into and passing through Secondary
Coil-winding (52) of Figure (7-8) causes and produces copper ions (643a xxx 643n) (Positive
Charged atoms 542a xxx 542n having missing electrons) when moving external electromagnetic
field strength (71a xxx 7In) is sufficient enough to dislodge electromagnetically charged electrons
(64Ia xxx 64In) from copper atoms making up copper wire material (52). Collectively, the resultant
positive electrical charged copper ions (642a xxx 642n) added together produces Positive Voltage
Potential (629) being electrically applied to choke-coil (56); whereas, the "Liberated" negative
electrical charged electrons (64Ia xxx 64In) added together provides Negative Voltage"
i am feeling about 90 percent sure this is how..  once you learn how to look at electric in the right understanding of flow and whats flowing and why you will see how potentials can be displaced in large quantities.. remember more winds more voltage.. thats because the positve is missing electrons and each wind is like a pully.. +1+1+1+1+1......they make the load lighter work. it is said you can remove all of the electrons from a atom and it will still be copper and hold its structure.
« Reply #41 on: March 01, 2009, 12:07:42 pm »
Great to see you pondering outlaw , that coil 10-4 sure is puzzling ... I dont understand it at all to tell you the truth ... I wonder myself how the overlapped copper bifilar is connected .
« Reply #42 on: March 01, 2009, 18:08:56 pm »
i think this would be the what to wire 6-1 to put off same sync pulse as 8-11
outlawstc
« Reply #43 on: March 01, 2009, 18:20:40 pm »
this photo is of the steam resonator set up... notice both sides the the cell share only one wire... he is fluxuating both sides from positive to negative .. its not like what the crossover circuit does.. the crossover maintains it polaritys to seperate sides.. think about it...
« Reply #44 on: March 01, 2009, 18:29:53 pm »
Yeah np Dankie, but none of these 'alternative'/extended em theories  are proven, it is all or nothing.
Some things easily overlooked about 10-4, but still not very clear how it should be connected:
(10-4) that are not only electrically connected in sequential order but likewise magnetically linked by
Inductance Coupling field (511/512a xxx 511/512n),
Increasing energy-yield (16/gtnt) still further is accomplished by increasing the number of Resonant Charging Choke Stages
(xxx 56/62n + 56/62n 1+ 56/62n2 + 56/62n ... etc. -S- xxx SS56/62n + SS56/62nl + SS56/62n2 + SS56/62n ... etc.)
of Figure (10-4) in "Sequential Order" ( -S-)
since the total number of Multi-Coil Magnet bifilar coils (56/62a xxx 56/62n)
serially electrically connected together are sequentially electrically
 linked to an equal number of serially electrically aligned Stainless Steel Resonant Coils
(SS/56/62a xxx SS/56/62n) ... allowing each/both bifilar coil assembly
(56/62a xxx 56/62n -S- SS56/62a xxx SS56/62n) to be electrically and magnetically energized in the same progressive
direction toward Water Gap (Cp) and away from blocking diode (55) of Figure (3-34) as to Figure
(10-1) and Figure (10-3) .
In Retrospect, the use of Stainless Steel composite coil-wire (430FIFR) consists of both
inductance and resistive properties (typically .0048 ohms per foot) which when combined together in
 metallurgical form .........
Stainless Steel bifilar Coil-Stage Assembly
(SS56/62a xxx SS56/62n)
is electrically placed between Magnet Coil-Stage Assembly (56/62a xxx 56/62n) and Water Gap
 Generally, magnet coil-wire length is longer than the Stainless
steel coil-wire length and magnet bifilar-coil (56/62) is placed on top of Stainless Steel bifilar-coil
(SS56/62) to maximize mutual inductance coil-field (Rp2)
« Reply #45 on: March 01, 2009, 18:41:28 pm »
unipolar and opposite Crossover waveform:
this effect is easily simulated and understood, think about these chokes as batteries connected parallel, voltage doesn't  add up.
current from higher voltage wants to go to low voltage, therefore 2 diodes over the chokes, 1 behind and 1 in front. WFC will see the highest volt.
still, very strange design this 10-11
(I havent yet focused on your desgns)
edit:
goal of 10-11:
This applies to the circuit:
Whenever, Voltage Excursion Point "P" is always changing in a given space-time, "State Space" is
referred to as “ Dynamic State Space;"
and
To ensure and maintain Capacitance Charging Effect (650) of Figure (7-4) across Water--
Gap (Cp) of (7-8) during applied pulsing operations (49a xxx 49n).
Crossover Voltage Wave-Form (780B) as to (780C) of Figure (8-2) is generally utilized by
not allowing Convergent Point "Q" of Figure (780B) to reach Electrical Ground Point (OV)
why  dynamic?
depending on gas compression.
To get 8-4 (=VS3 in 8-7)
8-5 (=VS2 I think)
or 8-6 (=VS4)
(8-1 (= VS1) is "static spacestate" not for this circuit)
« Last Edit: March 01, 2009, 19:25:39 pm by Alan »
« Reply #46 on: March 01, 2009, 18:51:08 pm »
I beg to differ , tom bearden proved it with his MEG .
Scalar waves exist , no doubt about it ... Bearden has a reputation , he wouldnt be saying this if it wasnt true .
« Last Edit: March 01, 2009, 19:37:38 pm by Dankie »
« Reply #47 on: March 01, 2009, 19:15:40 pm »
you are correct that it wants to go to a lower potential of unlike charge.. the positve stainless is connected to positve side of primary.. everytime the gates on the primary winding loop is closed alowing curent flow it allows electrons to escape primary and gives it positve ions.... these chokes are not doing what you think they are.. they are saturating with there own unipolar charges.. so all the electrons on the positve side of the stainless remain on the south pole untill they can be removed.. there no reason why the primary cannot feed positive copper ions in from a low voltage source.
