Author Topic: Vic Coil  (Read 42417 times)
0 Members and 16 Guests are viewing this topic.
Re: Vic Coil
« Reply #56 on: March 24, 2009, 16:12:42 pm »
Meter Readings               posts          ohms         inductance
                                      T - T             75.5           .103  mh
                                      A - H              3.6            87.4 mh
                                      E - D           1.76M             10 h
« Last Edit: March 24, 2009, 20:22:55 pm by johnbostick »
Re: Vic Coil
« Reply #57 on: March 24, 2009, 18:41:37 pm »
and what is amazing is that you got almost damn near close to 10.7 henries!!!! just as was calculated!!! you hit the money spot!......john i can't thank you enough for all you have done so far..........alonmg with dankie for aquiring the tiresome wire.....and dynodon for actually visiting and holding the vic itself........
HELL YEAH.
now.......when are you going to test it out......and how are you going to go about putting power through it?......we should keep it in the 12 volt 3.3 amp range as stanley has stated.....so many tests await this tihng......and just for dankie i would love to test this thing to see if it emits scalar waves.......if it does then dankie will have to get some form of medal or status on the forum....scalar wave engineer or something rather.
but damn you hit it right in the EXACT RANGE!!....10.7 henries range is just what we wanted....EXCELLENT WORK JOHN!
Re: Vic Coil
« Reply #58 on: March 25, 2009, 05:55:10 am »
Maybe I am missing a training session somewhere,
Don't Meters use an ac wave at a dedicated frequency to determine Inductive Reactance, therefore inductance - wouldn't that diode and resistive wire cause the test to be a little off?
Don't get me wrong I look forward to some testing, you are leading the way.  Much farther than I have gotten in this area.
  • Yes I got Jolted,
Re: Vic Coil
« Reply #59 on: March 26, 2009, 15:38:49 pm »
                                      T - T             75.5           .103  mh
                                      A - H              3.6            87.4 mh
                                      E - D           1.76M             10 h
John,
Looking great, I can't wait to read about your results.
Re: Vic Coil
« Reply #60 on: March 27, 2009, 05:30:11 am »
Thats a pretty mind-boggling inductance boost JohnB , connected the way you did , all north aligned ( NOT like figure 10-3b)
Must be pretty high volts/low amps  ?  10 volts , 160 milliamps ?
So the question is , what is 10-3 b for ??
Re: Vic Coil
« Reply #61 on: March 28, 2009, 06:11:04 am »
JB, you are getting a tremendous  amount I H from the steel wire alone. How long is the steel wire?
Re: Vic Coil
« Reply #62 on: March 28, 2009, 08:37:19 am »
john must be busy.
Re: Vic Coil
« Reply #63 on: March 28, 2009, 08:53:37 am »
What a beautiful piece of work
