Author Topic: Deleted  (Read 5140 times)
Re: Insulating high voltage zones
« Reply #8 on: October 22, 2008, 01:33:20 am »
I finally got my LCR meter the other day, measured my 3" tube set and came up with 3.9uF bare.
As stan states in his patent with 3" tube sets he hit resonance at 10kHz,
If 10kHz was his pump frequency, then his resonant frequency was 5kHz
The size of his inductance to have a resonant freq of 5kHz would be about .25 mH which would be some timy chokes.
If built on a 1" diameter air core 5" in length with 24 gauge wire you would only have 235 turns and a little over 1 ohm resistance.
This means that at least in this patent the tubes were most likely not insulated.
The bifilar he had in the International independant report looked big , a few thousand feet at least , they were not tiny at all .
wait what?...what's a thousand feet?
« Reply #9 on: October 22, 2008, 01:52:57 am »
« Last Edit: May 10, 2009, 15:56:13 pm by HMS-776 »
« Reply #10 on: October 22, 2008, 02:00:32 am »
In his patent he mentions 100 turns each which works out to really close to what I calculated above.
I think I'm going to insulate min though!
Without insulating I see many problems, mainly a huge voltage drop in the WFC since it would be dead shorted!
A huge voltage drop is what you are hoping for lol...  the purer the water the better , thats why you are adding a coating.
« Reply #11 on: October 22, 2008, 02:08:39 am »
He mentions that in his patent true , he mentions that his *electrical polarization* process could be *verfied* using a toroid and 100 turn coils but do you seriously think the process ends there with that very basic design and thats his actual water fuel cell?
« Reply #12 on: October 22, 2008, 02:20:15 am »
« Last Edit: May 10, 2009, 15:56:40 pm by HMS-776 »
