Author Topic: Deleted  (Read 7069 times)
Re: Replacing the VIC coil with an Ignition coil
« Reply #16 on: August 27, 2008, 12:48:19 pm »
well , w/e  freq  that allows highest voltage  you get 5 or 10 turn pots and sweep
i dont feel resonance is key here , pulsed opposite magnetic fields from bifilars is what does the work on the water
Explain further pls. The magnetic field does not directly go through the wfc, also both fields annihilate themselves if connected as for example the Dave Lawton circuit recommends. So the energy stored in the inductors is nearly zero. How can that perform any work?
Bifilar inductors are  wire resistors.
« Reply #17 on: August 27, 2008, 19:52:13 pm »
http://www.ionizationx.com/index.php/topic,478.0.html
i think this post shows what i mean by opposite electrical fields
