Author Topic: Alternator stator: Triangle connection or star connection  (Read 16779 times)
Re: Alternator stator: Triangle connection or star connection
« Reply #16 on: August 04, 2008, 04:30:49 am »
 DAMM I wish I could watch youtube videos.  :( :( :( :( :( :(
Well here you go!!! its just 2 pics and a battel cry!
and Jose, great circuit!
« Reply #17 on: August 04, 2008, 05:46:35 am »
Hi friends
OK  I will rebuid the same litle  set up again (anyway am waiting for bill of material fir the big one ) , will draw exactly which components I have in the set up , explain and send it all to the forum + attachments
Good luck
Yossi
« Reply #18 on: August 04, 2008, 05:50:30 am »
One more thing!!
forgot to tell
the "litle" setup was run with distilled water.
Yossi
« Reply #19 on: August 04, 2008, 11:07:16 am »
Hi friends
Good luck
Yossi
Thanks Yossi,
Looking forward to your component list!
« Reply #20 on: August 04, 2008, 14:15:29 pm »
Hi Steve
Here is the set up of the " mini cell"
I Did today again the experiment and want to correct a mistake about the amperage reading that I previously reported .
Apologize for that .
I run voltages between 10V ~ 25V and the amperage was not 5ma but 50ma
 Some comments:
1) in The original drawing of  "TheGuru2you" in you tube,  there was missing the rectifying diode D1.
2) R2 100 Ohm  should be 5watts minimum.
3) I am  re-using a custom made ferrite transformer with many windings. For that experiment enough to have any 1 to 15 ratio transformer.
4) The rotary SW1 is optional  eiher to  play with diffrernt frequencies either to easely adapt to to your HHO cell
5) DON'T EXPECT TO PROPULSE YOUR CAR WITH THAT MODEL!!!==> the circuit just show that resonant pulsating high voltage
     does create electrlysisl
6) I used distilled water. Somehow did not try with tap water yet..
Here attached below my schematics with components values.
Best regard
Yossi
  • OO-Rah!
« Reply #21 on: August 04, 2008, 14:54:00 pm »
Yossi
 ;D You think you can draw one up to work with mine  ;D
Spike
« Reply #22 on: August 04, 2008, 15:05:43 pm »
Am optimist !!!
a baby crawl first then he fly !!!
see you
Yossi
  • OO-Rah!
« Reply #23 on: August 04, 2008, 15:20:21 pm »
Yossi
It was worth a shot  ;D
Spike
